140Views23Replies
Author Options:
What to cast? Answered
Hello, I plan on casting some aluminium soon. However, I haven't decided on what to cast.... any ideas??
knutknackebröd
knutknackebröd
6 years ago
alrigth so i tried it, total fail:P wrong type of sand so the cast only got to like a cm in depth before collapsing...... tried again and the steel pot i used as a crucible burned through...... getting a new(thicker) pot soon and gonna add some clay to the sand, I read online it helps to keep the structure intact. just to answer my own question, I tried casting some seal stamps!
swapeasy
swapeasy
Answer 6 years ago
I use an oil based sand I get off ebay, it's called Petrobond.
The guy will sell you a single box for about $30.00 shipped.
You dont have to worry about moisture or clay content with this sand, it just works.
steveastrouk
steveastrouk
Answer 6 years ago
In general cast metal is brittle, so no.
JM1999
JM1999
Answer 6 years ago
It would depend on how much flex the alloy had.
With any sort of bow, there is no 'elastic band' that powers the bolt, instead the arms are the parts that flex and provide the spring to fire the bolt.
rickharris
rickharris
6 years ago
Jewellery - easy, profitable and different.
Kiteman
Kiteman
6 years ago
Jewllery - pendants & what-not.
knutknackebröd
knutknackebröd
Answer 6 years ago
hmmmm not really the jewelry type, might be good way to make S.W.M.B.O. happy though:P
Kiteman
Kiteman
Answer 6 years ago
True, or to earn a few extra pennies on craft stalls or eBay.
JM1999
JM1999
6 years ago
Knex, you would have the strongest structure around!
JM1999
JM1999
Answer 6 years ago
Well, there is already metal lego so metal knex is a unique thing.
Burf
Burf
6 years ago
If you're going to be sand casting, keep in mind that you won't get much in the way of fine definition. I would start with something like an ash tray or a good luck horseshoe or anything that can be refined with simple tools; a file, hacksaw, a Dremel Mototool, or an angle grinder.
swapeasy
swapeasy
Answer 6 years ago
I would not say you wont get fine detail. I get unbelievable detail with all my
sand castings. I use petrobond and sell my items at work, the customers love it.
knutknackebröd
knutknackebröd
Answer 6 years ago
true, however for a first time mould maker I dont think making something elaborate is the way to go
knutknackebröd
knutknackebröd
Answer 6 years ago
well I've seen quite a few fine detail castings around here, but it would probably be best to avoid anything too complicated the first time around.
knutknackebröd
knutknackebröd
Answer 6 years ago
haha not a bad idea to get things started:P might carve the mould from a tealight!
Mr_Liss
Mr_Liss
6 years ago
A gnome. Everybody needs one.
knutknackebröd
knutknackebröd
Answer 6 years ago
already have one, not an aluminium one though.....
swapeasy
swapeasy
6 years ago
Do you have access to a 3d printer?
I am using mine to print all kinds of animals and parts, and then I use them to cast in aluminum.
