90Views4Replies
Author Options:
What type of battery would I need to power 10m of RGB LED strips? Answered
For the summer, I would like to run two 5m strips of RGB LEDs in the cabin of my boat. I dont particularly want to run it off of the boat battery because I do not want to rain it while stationary. So my question is what type of battery, what specs, should I be looking for? Obviously a 12 volt battery because that is what the LEDs run off of, but is there a certain type I should be looking for, one that can handle the amount of amps the LEDs draw. Also if you could provide a link to a specific battery that would be helpful!
The specs for the LEDs:
Run off of 12 volts, (2) 5m Strips, approximately 5 amps per 5m -- so 10 amps total
Link to RGB LEDs:
http://www.amazon.com/gp/product/B00ASHQQKI/ref=s9_wish_gw_d5_g267_i1?ie=UTF8&colid=2YTJAFKDJWBSM&coliid=I2PXDOU6G8R0XG&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=1PT4GDRNRM4JE2691CXW&pf_rd_t=36701&pf_rd_p=2079475242&pf_rd_i=desktop
All suggestions and help are truly appreciated!
Wired_Mist
Best Answer 4 years ago
A large 12v deep cycle battery is the only way to go.
Your local auto parts store will have what you need :)
Even though the kit comes with a 5A power supply, it will only draw 3.3-4 Amps. Even less if you reduce the brightness with the controller!
I would suggest you buy a second Aux battery and hook it up in parallel to your Main ones. Then use a Relay between the positive leads of the batteries. This way you can power the lights off the second Aux battery, but still recharge it when the engine is running.
I drew you up a Crude Schematic on paint !
Now if $100-200 seem a bit much for an additional battery, You can always just wire the controller directly to your main batteries and use a relay just like what I drew down there. That way they will only be drawing current when the key is in the Ignition.
Wired_Miststeveastrouk
Answer 4 years ago
Yeah, Exactly what i was thinking !
Just had a brain wave too, For a spare battery try your local auto wrecker ! Not like it has to be a brand new one right?
steveastrouk
4 years ago
The amps aren't necessarily the problem. How long do you want to run them for ?
If you want them to run for 10 hours, you need a 150 Ah battery
