686Views28Replies
Author Options:
Whats is this little component called?(Picture included) Answered
And what does it do? Because i have a bunch of these and tell me what the little numbers and letters mean(In picture).
jewdusmax
4 years ago
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCcQFjAB&url=http%3A%2F%2Fwww.datasheetarchive.com%2F7809a-datasheet.html&ei=PFIzVZ3yJIK5ggSEu4O4Aw&usg=AFQjCNGvG7O5UuaLLk5qya-F0e2Qyx74kw&sig2=O-PHDr1wOZQ4H2PAT0BZSQ&bvm=bv.91071109,d.eXY
jewdusmax
4 years ago
http://www.datasheetarchive.com/dl/Datasheet-094/DSA0092727.pdf
this may help
CameronSS
10 years ago
You apparently didn't Google anything, there are pages and pages of information. As Nacho stated, it is a 9V voltage regulator. The center pin is ground. You put anything under +35VDC in the input pin (the left) and you get 9VDC from the output pin (on the right)
ReCreateCameronSS
Answer 10 years ago
Umm...yes i did i googled all the numbers and everything. But it would not find the part number of what it is. Also so the electricity could fluctuate from 12v to 35 volts and the output will stay the same? And the left pin is the one on the left by looking at it from the front?(where the numbers are)
CameronSSReCreate
Answer 10 years ago
The part number is 7809. The 78xx series are all voltage regulators, and the xx designates the output voltage. Pretty close to it. Yes.
ReCreateCameronSS
Answer 10 years ago
what are 87XX series called? I have a few and they are 8772 and0802 Eh...here is a pic of it still on the board Yes i know i did not google it,you get better info than i could find with google
DerinReCreate
Answer 10 years ago
I tried.No results of use.The part number shows it's a relay socket.Go figure.
ReCreateDerin
Answer 10 years ago
Relay? You mean Transistor?
ReCreatefrollard
Answer 10 years ago
hmm...i can find it on google...i think google hates me...anyways would you tell me what voltage they regulate? Since your so good with google?
ReCreateCameronSS
Answer 10 years ago
so the voltage will be very close to 9V all the time?
ReCreateCameronSS
Answer 10 years ago
Also i did not know it was a regulator...i though it was some sort of transistor
DerinReCreate
Answer 10 years ago
It is also lead-free,as shown by the dot marking.
DerinReCreate
Answer 10 years ago
It is RoHS compliant.
ReCreateDerin
Answer 10 years ago
Oh,Ok... Even if it had lead,this thing is so tiny,it would do literally nothing
CameronSSReCreate
Answer 10 years ago
Nacho already noted that it is a regulator. Your confusion is understandable. That particular form factor is called the TO-220 case, and many higher-powered transistors use that package.
NachoMahma
10 years ago
. 7809 is the part number. 9V regulator. Google "7809" for more info.
ReCreateNachoMahma
Answer 10 years ago
I google searched all the numbers and letters before and i did not find anything,Thanks Also what do these contraptions do?
NachoMahmaReCreate
Answer 10 years ago
. My bull feces detector just went off! Yep. I just Googled "7809" and half of the hits on the first page were for your component.
DerinNachoMahma
Answer 10 years ago
Confusion detector:Normal Level *reads* Confusion detector:*BEEP BEEP BEEP BEEP*
ReCreateNachoMahma
Answer 10 years ago
no i searched everything
All of the numbers and letters
See my search?
It does not find what i want at all
how was i supposed to know that i only search KIA 7809 A p1 . 429
Junk_Wizard
10 years ago
a more common one is the 7805, you could try looking up that one...
ReCreatecrazycommanche=US=
Answer 10 years ago
I don't think it is an old cap,because the device it came out of is pretty new And it has some sort of heatsink attached too
