4496Views3Replies
What's the best Dremel bit for engraving aluminum?
I want to engrave a design into a block of aluminum with my Dremel. It needs to be about 1/16" deep and 1/16" wide and consists of curves and lines. What is the best bit to use?
Best Answer 10 years ago
I would use a steel tapered cutting bit with either mineral oil or sewing machine oil to lube the bit.
Answer 10 years ago
Thanks! You really helped with my new instructable.
10 years ago
Something with fairly coarse teeth. Lubricate the metal with kerosene, mixed with enough clean engine oil to thicken it a bit. This'll stop the metal clogging your cutter.
