827Views5Replies
Author Options:
Whats wrong with my mid-cap airsoft magazine? Answered
I have had some airsoft mid cap magazines and haven't used them in a while, and when i went to use them they wouldn't keep feeding to the top. Some would go in but after about 5 it would stick inside the mag, any help.
diyoutdoorsman
diyoutdoorsman
Best Answer 9 years ago
Have you tried cleaning the internal components? Oil and other lubricants will often get gummy with age, particularly if they are just setting with no use. When my mags get where they won't cycle correctly, I clean them thoroughly with a solvent to remove all the gunk. I often use carburetor cleaner or break cleaner to cut the old oil, carbon, and dirt. These solvents are very flammable and caustic. Use them in a well ventilated area and wear gloves and safety glasses. Also, if your mags are made of plastic (an I assume they are) you should probably use a small amount of fluid in a inconspicuous area to test the potential of damage to the plastic. Some solvents will melt plastic like hot butter. After you have cleaned them with the solvents they will need to be re-lubricated with a light oil or maybe even graphite.
KnexFreak360
KnexFreak360
Answer 9 years ago
I tried silicon spray but the problem is they double up inside.
diyoutdoorsman
diyoutdoorsman
9 years ago
You might try cleaning and lubricating them.
KnexFreak360
KnexFreak360
Answer 9 years ago
Ya i tried silicon spray no luck and i cant take them apart no screws they are glued
diyoutdoorsman
diyoutdoorsman
Answer 9 years ago
Unfortunately, you just might be out of luck and will have to replace them. Sorry I couldn't help.
