125Views4Replies
Wheelchair Wheels
I'm a wheelchair user and I would like to change the side wheels and rims with a bike geared wheel and push handles.
I need someone, brighter than me, to work out how to combine the crankshaft and back wheel into one unit?
If this could be done, I would extend the pedal shaft to become handles which I could push with my arms.
Don't know if that is clear..
I've tried to add an image here, but Instuctables just not uploading anything!!!
If you have any idea about the wheel idea, I would be grateful to hear?
Many thanks
Richard
5 years ago
Here is one nice patent about it:
https://docs.google.com/viewer?url=patentimages.st...
I guess in an ideal world you would be looing for something like this but without the massive price tag ?:
http://riomobility.com/en/leverdrive/pivot-benefit...
And here you find some design idea that might be something for your liking:
http://digitalcommons.calpoly.edu/cgi/viewcontent....
Reply 5 years ago
Hi and let me first say thank you for such a quick response!
You got the idea spot on... the Rio and the Quantum Runner wheelchair look great. I work on distance, so needs construction to be robust.
I now need to get someone to work on design and fabrication! :-)
Thanks again... great advice!
Richard
Reply 5 years ago
Had another thought on the cheap approach:
If you take the rear wheel of bikes with no gear shifters - the old type ;)
They have a free wheeling hub inside and an almost suitable ration for your form of propulsion.
The only problem is the brake that is working as soon as you go against the rotation, which might to be removed or disabled.
But if the handles are connected to the sprocket they should work just fine.
Push down to make the wheel turn, pull back with nothing because of the free wheeling hub.
Not sure if the rotating direction can be changed though but could be simple if both sides of the axle are identical inside the hub.
5 years ago
Hope this helps!?
