294Views10Replies
Author Options:
Where could one acquire a small O2 gas cylinder? Answered
Where could I go to get small O2 tanks without much expense for individuals without health issues or special licenses of any sort?
I DO NOT need anything of a specfic grade as this is for combustion.
I wont be breathing this (at least not on purpose)
I want is the small medical sized bottles
Burf
Burf
Best Answer 10 years ago
Is this for medical purposes or industrial use?
Medical supply companies sell and lease the former, welding supply companies sell and lease the latter.  Industrial use oxygen is NOT to be used for medical purposes, ever.
The Ideanator
The Ideanator
Answer 10 years ago
I intend to use the oxygen for combustion so the quality doesnt matter much. What I want is the small medical sized bottles.
Burf
Burf
Answer 10 years ago
Okay the edits to your question makes it easy:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=91314-13877-307343&lpage=none
The Ideanator
The Ideanator
Answer 10 years ago
Wow, thank you! Its the perfect size too, about the same size as a tank of mapp gas.
Burf
Burf
Answer 10 years ago
You're welcome.
Once you clarified the question, I knew exactly what you were looking for.
The Ideanator
The Ideanator
Answer 10 years ago
Could I get medical oxygen without a condition that requires it?
Burf
Burf
Answer 10 years ago
It depends on where you live I believe.  I presume you are in the U.S., some states require a prescription, others don't. Just call a local medical supply place and ask.
steveastrouk
steveastrouk
10 years ago
In the UK here, you can buy small O2 cylinders for a shop gas torch from B+Q (the equivalent of Home Depot or Lowes)
seandogue
seandogue
10 years ago
Medical grade oxygen is, As I recall, only available with a prescription.
Interestingly enough, however, brewers use it, so you might want to check with brewing organizations in and around your area. the following link is from a meeting in your neck of the woods...
http://www.mbaa.com/Districts/Michigan/minutes_achive/minutes2006_03_23.htm
Quote: "There was some discussion about what kind of oxygen brewers should use when adding oxygen to help yeast metabolism. Welder and aviation grades are not suitable, only pure medical grade oxygen should be used...."
Re-design
Re-design
10 years ago
Do you really need med. oxygen?
Or can you use industrial oxygen?  If so it'll be much cheaper and probably available where ever gas welding supplies are sold.
What's your project?
And you do know the fire/pressure/heavy object dangers associated with this and if you don't look it up before proceeding.
