167Views17Replies
Author Options:
Which Circuit Is Best To Use? Answered
I am trying to configure a LED circuit that allows me to charge 1.2v batteries using a solar panel. But i also want the solar panel to be used as a light sensor(detector) so during the day it charges..then at night the battery kicks in and lights up my LED strips. This is my first upgraded version using a schematic software.. Please help.
Should i add 2 indicator LED's to let me know when the battery is being charged and when the battery is in use?
I attached two images..one containing a LM317T and the other without. Just need some advice! Thanks
iceng
iceng
Best Answer 5 years ago
First one assuming the red led fwd voltage even lets current flow. You may have to reduce the led count.
islandboii242
islandboii242
5 years ago
Ok what if im using a LED Strip of lights...the strip contains about 60-80 LEDS?
iceng
iceng
Answer 5 years ago
The strip uses much more current so you need a higher current transistor as the N channel MOSFET.
BUT there is no way you can expect a small solar array to charge an 80 AH battery needed to run the LED strip :-(
islandboii242
islandboii242
Answer 5 years ago
My battery will be 1800 mAh 10 1.2v AA batteries. Sorry i didn't Mention this, and the solar array will be 1.25 - 1.5 watts
iceng
iceng
Answer 5 years ago
78 led / 3 => 26 groups x 19ma => 500ma @ 12V => 6 watts
1800 mah/ 500ma => 3.6 hours
Your solar cell needs to be bigger and stronger.
Your battery will run out in 3 hours.
islandboii242
islandboii242
Answer 5 years ago
I sent you a message in your inbox. What i wanted to know was your schematic does this have the two most important features i need which is:
1. Using Solar Cell AS Light Detector (Photo Resistor)
2. Battery charge protection (so battery doesn't over charge or drains?)
iceng
iceng
Answer 5 years ago
As it gets dark base current begins to flow through the solar cell turned into a resistor turning on Q1 which raise the gate voltage about 10 volts which turns Q2 on to deliver heavy current to the LED strip...
islandboii242
islandboii242
Answer 5 years ago
Will this still charge the battery?
iceng
iceng
Answer 5 years ago
Yes, study the ckt notes.
islandboii242
islandboii242
Answer 5 years ago
Designed it in my software and here is your design on left...question about the battery being over drained.
iceng
iceng
Answer 5 years ago
Your circuit does not have a resistor to guarantee the mosfet gate is truly at zero and non-conducting discharged when going from dark to sunlight.
islandboii242
islandboii242
Answer 5 years ago
ok understood ...if i wanted to add a feature of red and green led to indicate when battery is being charged (red & green) via solar cell and the other led (green) when the battery is now being used after the sun goes down?
Also for the mosfet should i add a heat sink also because this circuit will be running 24/7.
islandboii242
islandboii242
Answer 5 years ago
ok awesome thanks...this is the final design with pcb..top and bottom layer. Let me know what you think.
iceng
iceng
Answer 5 years ago
Could you mean over charged ??
over drained means over dis-charged..
For over charging add resistance in series with charge path.
I worry more about not turning the mosfet fully on.
steveastrouk
steveastrouk
Answer 5 years ago
Your LEDS are probably ~12W. you need more than 12 hours of light for each hour of operation.
Steve
islandboii242
islandboii242
Answer 5 years ago
:-( Looks like i need to redesign...What i am trying to create is a back light sign that uses solar/battery which gets charge during the day and after dark the led strips turn on. But i have a small space to work with for the solar array.
steveastrouk
steveastrouk
Answer 5 years ago
There are some changes you could make, by not using off the shelf LED strip, you can eliminate the dropper resistors and make a bunch of LEDs more efficient.
Downunder35m
Downunder35m
5 years ago
For less than 5 bucks you can get a solar garden light that has everything you need inside.
Your images show 12V batteries but your text says 1.2V - which one is it??
For 12V you want to use a proper solar charger with automatic shut off and overcharging protection.
Only a few bucks on Fleabuy.
