52Views4Replies
Author Options:
Which adhesive can be used in chemical environment? Answered
Searching for an adhesive which can be used for chemical glassware where it doesn't react with chemicals and having thermal stability as well.
steveastrouk
steveastrouk
4 years ago
We have chemicals here that can dissolve any glue you can think of, but they are specific to the glues. Epoxy is very susceptible to formic acid for example.
Downunder35m
Downunder35m
4 years ago
It all depends on the chemicals.
Some 2K epoxies are reall good in this department but no matter what you try you temp limit will be at around 100° C before the stuff softens.
If you want it for repairs replace it instead, if you want to attach something use metal clamps designed for the purpose.
Once glass is broken there is no such thing as an easy repair that last to chemicals and high temps.
Kiteman
Kiteman
4 years ago
It depends on the chemicals, but you're probably looking at a two-part epoxy resin. It won't be pretty.
