9069Views17Replies
Author Options:
Which adhesive to use for fibreglass? Answered
I want to glue hard plastic brackets to the inside of a fibreglass pond. Contact area will be around 18" x 2". They will be continuously underwater. Is Araldite the best glue to use for this or is there something better?
thecookiemonster
Best Answer 10 years ago
araldite rapid in the syringe is good because it dries quick and isn`t messy because it automaticlly mixes them!!!
AndyGadgetthecookiemonster
Answer 10 years ago
I've just stocked up with Araldite Rapid today. No need for the syringe as I'll be emptying the tubes which will be 50/50 anyway (and better value ;¬)
lemonie
10 years ago
Araldite(R) is good stuff, but I find Wilkinson cheap-o 2 part epoxy is also pretty good. Key the surface properly and you're probably alright with either. L
lemonieKentsOkay
Answer 10 years ago
Can't/couldn't be bothered - new hat? L
KentsOkaylemonie
Answer 10 years ago
Yah, thought I'd tout it about for a while.
lemonieKentsOkay
Answer 10 years ago
I was thinking of getting a hat myself to keep my hair in place... But something acceptable to wear into the office. L
lemonieKentsOkay
Answer 10 years ago
Well what do you think (ignore glasses - not mine)
KentsOkaylemonie
Answer 10 years ago
Good golly... You look younger than I pictured you. I'd say either a deerstalker or a wide brimmed fedora. A bowler would look interesting.
lemonieKentsOkay
Answer 10 years ago
Fedora is probably best out of those L
KentsOkaylemonie
Answer 10 years ago
I have the Indiana Jones Vintage Fedora, over the past year it's proven itself to be a worthy companion.
lemonieKentsOkay
Answer 10 years ago
I'll let you know if I find something (and buy it) L
AndyGadgetlemonie
Answer 10 years ago
Thanks Lemonie. I've used the Wilco epoxy in the past and found it was a bit more flexible than Araldite® when it was set. I think I will go for the 'genuine article' as I'm wondering if the constant wet may penetrate the Wilco epoxy more. It's one of those things which would be tricky to repair if it all came apart, so I'll spend the extra to try and get it right once.
(BTW, the Wilkinson UHU® equivalent is rubbish ;¬)
lemonieAndyGadget
Answer 10 years ago
Araldite may be a safer bet, but half the job is in the surface preparation. L
KentsOkay
10 years ago
Two Part Epoxy, or JB Weld.
AndyGadgetKentsOkay
Answer 10 years ago
Hi RS. J.B. Weld isn't something you see in the shops in the U.K. and their website FAQs actually recommend a different product (Waterweld or J-B Stik) if the glue is going to be wet all the time.
