86Views3Replies
Which poteniometer for 8 ohm speaker into TEAC AG-980 Amp?
Hi there, I have this 65W amp hooked up to two pairs of JBL Control Ones (8 Ohm) and one Fenword 8 Ohm Speaker. This uses A/B/C/D with the amp's multi zone function. The Fenford is in our bathroom area (it's a small gym) and I want to attentuate the volume just for this speaker. Any idea which potentiometer I can solder onto the cable to damp the volume?
3 years ago
This monster pot is toooooooooo small for what you want to do !
Listen to biochemtronics...
Answer 3 years ago
Blast !!!
Click the pic to see the whole image...
3 years ago
A simple pot in this circuit will severely overheat and stop working. An L-Pad volume control will work perfect for this application and the system will still see necessary 8 ohm load no matter what you set the remote speaker's volume at. You don't mention whether this is a stereo or mono speaker application. I would suggest a 100 watt 8 ohm L-Pad. You can purchase these from nearly any electronics supplier for either mono or stereo applications at a cost of between 10 and 20 dollars. They are easy to wire up. Best of luck.
