126Views12Replies
Author Options:
Why does my four wheeler spit liquid out of my engine when i start it? Answered
My four wheeler has a hard time starting, but when i get it started a black tube spits liquid out of my engine all over the place. What do i need to do to get it to run fine again?
Chase22
Chase22
4 years ago
It is a 1995 wolverine 350, I am in Utah and it is gas. It was running fine then my friend and I saw that the drain was disconnected. I don't know much about four wheeler's, but my friend does. It started when he put it on but it was backwards. and the black hose goes from my engine to my carberator.
Kiteman
Kiteman
Answer 4 years ago
So... it's fixed?
Chase22
Chase22
Answer 4 years ago
no
Quadrifoglio
Quadrifoglio
Answer 4 years ago
If you are up for it, buy a manual ($15.00 from Amazon https://www.amazon.com/Yamaha-Wolverine-Service-Maintenance-1995-2010/dp/B00JEK87GQ/ref=sr_1_1?ie=UTF8&qid=1467944445&sr=8-1&keywords=1995+wolverine+350+manual). Most manuals will have the actual names of the parts, what they do, troubleshooting, and how to fix them. When it comes, grab your friend and work through the sections that include the crankcase vent.
Also, take your question to an ATV forum like Yamaha Wolverine 350 / 450 http://www.bluetraxx.com/forums/yamaha-wolverine-350-450/.
rickharris
rickharris
Answer 4 years ago
It sound like this is a crankcase breather pipe which normally feeds into the air inlet or the top of the crank case.
i guess the fluid is black oil and you have fixed it.
Kiteman
Kiteman
4 years ago
If you cannot identify the liquid, or the orifice from when it came, take the infernal machine to a professional.
Jack A Lopez
Jack A Lopez
Answer 4 years ago
There is wisdom in this answer.
Erm, there is also a typo in it:
http://www.thefreedictionary.com/whence
But more importantly, there may be something to this notion that knowing the names of the fluids, and the names of the parts of the engine and such, that this knowledge is a prerequisite to being capable of fixing the darned thing.
iceng
iceng
4 years ago
Almost sounds like a four cycle leaky valve.
Quadrifoglio
Quadrifoglio
Answer 4 years ago
Or bad rings. Or an out of round cylinder. Or a blocked oil return. Or bad timing. Or if it has been mudded or swamped….
rickharris
rickharris
Answer 4 years ago
Could just be condensation, perhaps the black pipe is the exhaust.
leaky aircon overflow
Any number of seriouc fluid leaks.
iceng
iceng
Answer 4 years ago
Your correct about all the failure modes.. Four wheelers around the high desert, where I live, get into sand a lot.
Maybe after a good first cleaning and an oil change, Chase22 will let us know more.
Age, type, service record, second hand and where in the world could help the diagnosis :-)
rickharris
rickharris
4 years ago
OIL
GAS
Or water
Or a mix of water and oil?
It makes a big difference.
Type and make of vehicle
Exactly where is the liquid coming from
Does it run well otherwise
Milage
Vyger
Vyger
4 years ago
What kind of liquid ? Your problem has a lot of holes.
