328Views8Replies
Why does this boost converter circuit not work?
I tried this circuit using a 3.7v supply and instead of a 12v Zener I used a 5v Zener. I also used a 22uH inductor. I get 5v no load but when I add a load the voltage drops a bit and the current is 50ma max. Why is this not working and what could I change to make it work? If this is the wrong circuit altogether, then what discrete circuit would work?
http://www.aaroncake.net/circuits/6-12conv.asp
5 years ago
Well you should only get 5 volts with a 5 volt Zener and what is the 3.7 volt supply IE a NI battery what MAH?
Answer 5 years ago
it's a 3.7v lithium ion battery 2800mah
Answer 5 years ago
Battery is small for that booster, the booster draws 2 amps and you have less than 3 amp hours for that booster you need 8 to 10 amp hours battery or the power will just die when you load it. (8000 mah to 10000 mah)
Answer 5 years ago
thanks
5 years ago
The resistance values are all wrong for that low an input voltage.
And the inductor core may be wrong too .
Usually start to make a direct copy to verify you got it wired right and then experiment.
Brake the connect at R6 and see if that Q1, Q2 oscillator is a stable SQ wave as a start.
Answer 5 years ago
what do you think the resistor values should be?
Answer 5 years ago
Your reducing the voltage by 63%
Try 2.2K => 1.5K .... 4.7K => 3K and see if it oscillates.
BTW change that SQ wave to a narrow pulse wave because of values.
The inductance seems high.
Answer 5 years ago
it is oscillating with the original resistor values and the circuit is boosting the voltage to 5v, but if I add a load, the voltage will drop because the current output is so low
Answer 5 years ago
Surely you know you said that before.
Ever consider the lower R values may give you the power your wanting.
And the 0.5mm is .019" which is a 24 gauge magnet wire but not enough to calc the real inductance...
Answer 5 years ago
ok thank you
