3784Views13Replies
Author Options:
Why doesn't the butane gas from my lighter light? Answered
I got a jet lighter that burns butane (it is really cool, I can melt pennies). The lighter lights when I press the striker (pizo spark), but when I try to light the butane that I can make come out of the lighter from pressing the button half way in, I can't light the butane. Why is that?
Afif_D
Afif_D
10 years ago
Because its sad as you are not treating it properly..
OR because its BUTANE...
OR because its METHANE...
OR because its ETHANE...
OR because itsPROPANE...
OR because its CnH2n+2...
lemonie
lemonie
12 years ago
You may be igniting it in the wrong place. If this thing is like a mini blow-lamp you have the right mix of gas & air where the piezo igniter is. Once the (unburned) mixture leaves the lighter it is further diluted with air such that it is too weak to ignite. If you can block the air supply you might get a rich jet of butane out of this. L
tanis9319
tanis9319
Answer 11 years ago
lemonie wats with the l at the end L?
lemonie
lemonie
Answer 11 years ago
It's an habitual signiture (RETURN, RETURN, SHIFT-L)
L
tanis9319
tanis9319
Answer 11 years ago
sorry bud didnt know
lemonie
lemonie
Answer 11 years ago
Don't be sorry, people tend to pick up on me when I don't!
L
frollard
frollard
11 years ago
I had one of these - I think it got wet, or got plugged on the air-intake port with lint or something. Either way, these are EXTREMELY balanced jets to get that perfect flame - try blowing it out gently 'backwards' to clear the intakes. They get finicky over time and I'm not sure why.
Thelonelysandwitch
Thelonelysandwitch
Answer 11 years ago
no, it isn't clogged, it does light from the spark in the lighter, but when I make only the butane come out, It doesn't manually light from another source of flame (i.e. match, other lighter, candle etc.). I just want to know why.
frollard
frollard
Answer 11 years ago
Thats pretty simple - the 'fire' in a jet lighter is pretty far inside the jet system. The gasses, which burn readily at stoich mix are moving too quickly out of the lighter, and dont burn 'out in the air' as quckly as the gasses are expelled from the lighter. At best, it snuffs itself out, or burns an orange flame.
benz_z
benz_z
11 years ago
i have a dirt cheep china-town lighter some times the butane doesn't go into the lighter if the jet part doesn't hiss theres no butane.
Thelonelysandwitch
Thelonelysandwitch
Answer 11 years ago
no, there is butane in the lighter, I can light it from the striker on the lighter, but it doesn't light from a match or candle.
11010010110
11010010110
12 years ago
if you fill something with the butane you may be able to ignite it search on youtube for origami jet engine
