440Views6Replies
Author Options:
Why is a sponge easier to bend when it's wet? Answered
A cellulose sponge  (and even a plastic sponge that doesn't seem to change size when it's wet) is much more flexible when it's wet.  What's happening?
canucksgirl
canucksgirl
Best Answer 9 years ago
Whether a sponge is natural or synthetic, it is built up of cells that form holes which allow it to absorb water.
When the sponge is dry the cells contract making it fairly rigid especially if its a natural sea sponge. It may not appear to change size much at all, but it in fact does throughout its entire structure.
When water is introduced, the cells expand and it becomes more flexible.
Its like a piece of tall grass. When its 'wet' in its natural state, it's fairly flexible; but if you pull it out of the ground and let it dry, it will likely snap if you try and bend it.
mole1
mole1
Answer 9 years ago
So in the swelling (by adding liquid), it's the elongation of the walls between points of contact that makes them buckle more easily?
CameronSS
CameronSS
Answer 9 years ago
Ever played with a "push puppet" where pressing a button on the bottom loosens the strings, and it collapses? Same sort of thing. As it dries up, the strings tighten, and everything is pulled together. Wetting it loosens the strings, and everything goes wobbly.
canucksgirl
canucksgirl
Answer 9 years ago
Good analogy... i was looking for a similar explanation, but it wasn't coming to me at the time.. Good call.
canucksgirl
canucksgirl
Answer 9 years ago
Well I'm not a Scientist, but from what I recall, the structure of a sponge (when dry) contracts creating a tighter more rigid shape. When wet, the structure (as you said) elongates making it more flexible.
Re-design
Re-design
9 years ago
The water lubricates the joints between the cells and makes the sponge more flexible.
