101Views13Replies
Author Options:
Why is my power supply over-herating? Answered
I have a very simple power supply build to power effect pedals
220VAC --> regular 12vDC wall wart rated at 1A --> 9vDC (7809) regulator with 220uF on the in and 1uF on the out -->1  load rated at 250 mA
It's perfect except one thing... it over heats quickly, which will eventually lead to damage in a way or another.
Please advise
Thanks
Yonatan24
Yonatan24
5 years ago
What heats up: The power supply, Or the 7809 V-regulator?
7805 heats up: Enhance the size of the heat-sink
Power Supply Heats Up: Try this, Or use a power supply that is able to deliver more current/amps
mhanna3
mhanna3
Answer 5 years ago
the wall wart adapter board is heating up. It delivers 1A and only a regulator connected to it. Im confused why its heating up.
-max-
-max-
Answer 5 years ago
Do a easy calculation, see what voltage is going into the regulator, subtract 9V, then multiply that difference to the current you are pulling from it when it is working. That will tell you how much power is being dissipated in the regulator.
-max-
-max-
Answer 5 years ago
I calculate it is about 2W, Not much heat at all. There could be a short circuit present somewhere, or faulty wiring. It could be that one of the diodes for the full wave bridge rectifier has failed and is overheating.
rickharris
rickharris
5 years ago
1. Because you are drawing more current than the regulator can provide.
2. Heatsink as below or higher rated regulator.
mhanna3
mhanna3
Answer 5 years ago
I just did some tests, the regulators dont heat up.. Only the wallwart board does.
Can the regulator be sucking current from the wallwart adapter ? Does that make sense ?
steveastrouk
steveastrouk
5 years ago
What sort of heatsink have you got on the 7809, which is dissipating nearly a watt ????
iceng
iceng
Answer 5 years ago
+750mw
A wall wart rated 12v at 1A may be delivering 15Volts at 3/4amp
mi5a
mi5a
Answer 5 years ago
the wall wart i'm using outputs 12.5 VDC with no load connected and rates at 1A
it is then connected to a 7809 circuit with a 250mA load 3V drop ... so power is 0.250*3= 0,75W thats around 49degC rise based on the datasheet
steveastrouk
steveastrouk
Answer 5 years ago
There's your answer: add a heatsink.
iceng
iceng
Answer 5 years ago
Probably a good switcher wall wart.
We can just touch a 50degC plate but adding ambient makes the.
Only you can best decide how to cool your supply.
May be you could hack the wall wart to be a 9v output.
mi5a
mi5a
Answer 5 years ago
Thats actually an idea worth tackling !
ill give it a though
Thank you iceng
mi5a
mi5a
Answer 5 years ago
i have no heatsinks on there !
I'm currently testing and reporting to see which component (7809 or wallwart) is dissipating the heat.
Will report back
