12779Views43Replies
Author Options:
Why is my step up converter not increasing voltage and why output is a little lower than input? Answered
My step up converter is not working ,it wont increase the voltage . I used a multi meter and the output ends up being lower than the input like for example when I connected the battery to it, the battery was at 8.40v and I checked the output and it was 8.10v . I was trying to make a DIY speaker for the first time,  I am new to this.
step up converter  is called a MT3608 LM2577. I got it off of aliexpress.
https://www.aliexpress.com/item/DC-DC-Adjustable-Boost-Module-2A-Boost-Plate-2A-Step-Up-Module-with-MICRO-USB-2V/32668154181.html?spm=2114.13010608.0.0.a2VAYu
The battery i used is off a battery pack .it is 8200 mah and 9v
DotEXEGaming
DotEXEGaming
3 months ago
This happened to me previously and I found a quick and easy way to fix this: First, make sure that the input and output terminal aren't shorted (check VIN+ with VIN- and VOUT+ with VOUT-). Then, turn the trimmer potentiometer clockwise until you hear a clicking noise (you might not hear anything) and connect the battery now. Connect a multimeter as well and begin turning the trimpot anti-clockwise until you reach your desired voltage. If this doesn't work, try another boost converter. Hope this helps!
ArtR18
ArtR18
2 years ago
I had the same problem. Clockwise produced nothing, then I turned counter clockwise and it adjusted fine.
Regis35
Regis35
Reply 1 year ago
This happens when the ss34 diode gets damaged try replacing it and it should work fine
P.S. you can find them in old power banks (probably doing the same thing as here)
Alex345
Alex345
3 years ago
But it wont do anything when i turn the screw. nothing seems burnt
Uggima
Uggima
Answer 2 years ago
Yeahhhh i made the same mistake with those exact boost converters, doubt this will help you but might help someone else... Keep turning it, think the pot on the ones I got is ~100 turns for the full range.
And as for bad design, Vfb overvoltage is protected by R2 and the fact that the MT3608 refuses to make its Vout higher than 32v
y8492b
y8492b
3 years ago
Second thoughts, since some modules may be designed with the pot shorting clockwise, put the pot midway, and keep the input voltage below 6 volt, until the sense of the pot has been established.
Moral of the story on this one, as always, is to get and check the datasheets for all the devices in your designs.
y8492b
y8492b
3 years ago
The problem with most of the MT3608 and SX1308 modules is not the device, but the same flaw in the circuit design. If you look at the datasheet for these, which actually the same, you will find that the absolute maximum voltage allowed on the FB pin (feedback) is 6v.
Unfortunately, this can be easily exceeded because of the simple use of a 10k pot in the resistor divider from VOut to the FB pin. In operation FB is expected to be about 0.6V, but as the 10K pot can be reduced to zero, it can put VOut on the FB pin.
As the pot is turned (usually anticlockwise) the voltage on FB will increase, until it exceeds 0.6 volt and the device turns off. At that point the module will simply pass through the voltage from VIn to VOut via the inductor and diode.
Which means when the pot is connecting FB to VOut and VIn exceeds 6v plus a diode drop, the device will be destroyed.
Other than modifying the circuit, the best approach is to always turn the pot fully clockwise (most designs), then apply voltages and very slowly start turning anticlockwise for the required output.
Alex345
Alex345
3 years ago
i got the step converter that is 6a and can supply 100 watts is there any resisters i should use so I wont surge damage my components and so the volume will not lower.
iceng
iceng
3 years ago
When the booster power is greater then the amp power a resistor is not that useful and I believe the heat-sink will help the boost survive first power on..
iceng
iceng
3 years ago
Here are some fuse facts worth consideration;
A fuse is a lot slower to blow (melt sag open a circuit) then a semiconductor (tiny solid state PN junction can smolder to death)..
But then the booster has that nice metal heat sink => device to cool the Solid State PN Junction for a moment more time before junction reaching 130'C..
So it is a race between fuse and junction..
Also a 6A fuse probably will work a few seconds at 6 amps..
Yes, there are different speed fuses.. Please avoid all automotive fuses..
I show you the very fastest Fluke meter fuses I can get, but not on a Sunday so I repaired it.. See how fine the fuse wire material is compared to the readily available buss fuses..
The last is a 5A 32V fast mini buss fuse that may be able to save your booster from accidents.. I would get ten..
Alex345
Alex345
3 years ago
when told about the fuse do you think that an 6amp fuse could work temporarily so it wont kill the booster
Alex345
Alex345
3 years ago
and would that 6a converter still give that volume problem
Alex345
Alex345
3 years ago
the new one i bought is similar to the old but wont work because its only 2a and would be killed by the amp so ill have to wait to but that other new one then. but is there a way I can still use the new 2a one i bought or maybe with out the converter without the volume going down or with out damaging anything if not ill just wait
Alex345
Alex345
3 years ago
so should i try getting bigger step converter. Because the amp can go to 28 v and the new boost i orderd can go to 28v to
iceng
iceng
Answer 3 years ago
Nice find it has a maximum of output 6A..
Assume your amp is using 100W then the boost voltage out = P/A= 100/6 = 16.6 vdc...
iceng
iceng
Answer 3 years ago
If the amp can use a 100 watts then any booster must also be able to supply 100 watts...
Watts are output volts x amps and the battery more...
Example P=VxA and A=P/V
@ 28 volts Amps = 100/28= 3.6 Amps
@ 14 volts Amps = 100/14= 7.2 Amps
If 3.6A kills your Booster then 7.2A will also kill it at any loud note...
You need a power supply that limits output current to whatever it was designed to deliver...
Alex345
Alex345
3 years ago
would that work for when i can buy another part
Alex345
Alex345
3 years ago
https://www.aliexpress.com/item/100W-DC-DC-DC-3-35V-to-3-5-35V-LTC1871-Booster-step-up-Step-up/1967921037.html?spm=2114.01010208.3.2.Wtmu8t&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10068_10130_10136_10137_10060_10138_10155_10062_10156_10154_10056_10055_10054_10059_10099_10103_10102_10096_10148_10147_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10178_10110_10111_10112_10113_10114_10181_10182_10033_10078_10079_10077_10073_10070_10123_10124-10051_10112_10033_10077,searchweb201603_1,ppcSwitch_5&btsid=05706ec8-0728-496c-8d1b-9c46fd2d2a4c&algo_expid=671bd1d8-c0e5-4bbf-9477-8224dd05ee03-0&algo_pvid=671bd1d8-c0e5-4bbf-9477-8224dd05ee03
Alex345
Alex345
3 years ago
whoops the amp can only go up 24 v and the step up can go supply 28 v but that still would still kill the step up is there a way i can use the step up with out killing it because i wont be able to buy something that could give more amps for a while
iceng
iceng
3 years ago
Good !
You realize the amp can try to pull 100 watts from a booster that can only deliver
14 volts at 2 amps thats only 28 watts.. No wonder anything above a whisper will blow the booster...
Alex345
Alex345
3 years ago
btw the amp is 2x50w each speaker is 50 watts
Alex345
Alex345
3 years ago
ok thank you ill i am going to do that
iceng
iceng
3 years ago
Why don't you use two batteries in series = under 18 VDC ? Give you double the time too..
But lets do the math for current... Output current over 2A max kills the unit and the efficiency is only 75% at full output... So lets work with 1.5 amps average where maybe Eff=90% >> 1.1 loss.. Put a 1.5 a fuse on the output later a 2A fuse.
Before energizing with the amplifier adjust the pot to deliver 14v You may have put some small load in order to make the booster work use an incandescent
Average Input current = 1.5Aout x (14v/8.8v) x 1.1 loss = 2.7 Amps input..
Any way, a quarter ohm resistor in series with the input will cut back 1amp input..
You make a o.25 ohm resistor by putting four one ohm 1/2 watt resistors in parallel..
Be sure to click the pic to see the whole image !
Alex345
Alex345
3 years ago
how can i stop the surge current damage
iceng
iceng
Answer 3 years ago
A resistor in series that is removed with a switch after 20 sec.
And I can't, until I know the circuit you are feeding the 14 volts to...
Fiure the R.
Alex345
Alex345
3 years ago
The new one I ordered is from different seller
iceng
iceng
3 years ago
BTW I'm ordering two just to see the output..
iceng
iceng
3 years ago
What is voltage are you trying to boost up to ?
Alex345
Alex345
3 years ago
it bought a new one and i have another problem my diy speaker when turned on is at first loud but then the volume lowers even without the boost module
iceng
iceng
Answer 3 years ago
Sounds like you are surge current damaging your modules.
When you first generate the higher output voltage.. There is initially a 3 to 7 times current draw that could over load the unit... BTW did you first adjust the output pot without a load for the exact voltage you want ?
Then you could be draining the little battery.. Remember the battery must supply more current in proportion to the voltage increase and 93% efficiency means 7% is used to run the booster... Battery Current A = Speaker Current x (Vout/Vin) x 1.07
Alex345
Alex345
Answer 3 years ago
i checked without load nothing happens
Alex345
Alex345
3 years ago
how do i check with out load
iceng
iceng
Answer 3 years ago
Simply remove the out wires and put a volt meter on the output and try the pot again..
Alex345
Alex345
Answer 3 years ago
It wont do anything
Alex345
Alex345
Answer 3 years ago
I wont do anything
iceng
iceng
3 years ago
What happens when you turn the pot one way or another ?
Alex345
Alex345
Answer 3 years ago
nothing
Alex345
Alex345
Answer 3 years ago
niether decrease or increase
Alex345
Alex345
3 years ago
When i bought it. it said boost
Yonatan24
Yonatan24
3 years ago
Did you check that it's a step down (buck) vs. step up (boost)?
Did you check with load or without load?
Are there any burnt components - could you have ruined it?
Is your multimeter working properly?
Buy another one!
iceng
iceng
Answer 3 years ago
Wow...... Good advice Yonatan,
Can I assume that you can read schematic drawings now ?
Yonatan24
Yonatan24
Answer 3 years ago
Nope. Nothing has changed since then.
#1 - because I was lazy to read Chinglish.
#2 - tip that I know from checking regular power supplies
#3 - from experience (hint: wrong polarity and... BOOM! :)
#4 - also from experience (messing up an expensive multimeter so it shows that an 18650 battery is 20V :)
