113Views7Replies
Why's my PC moniter not displaying anything?
Just after i turn the power on, the cpu and the moniter turn on, the power indicator of both of them is on;
but the moniter is not displaying anything after that!!!!!but still its power indicator is on. What's the prblm??????
7 years ago
I had the same problem when i check the cable that goes to CPU it is damaged. The screw is broken so it is loose. I bought new cable then it worked. Another chance is the computer goes to sleep mode when nothing is done in computer for a long time, in my computer after i pressed enter or wake up button it will only display after a long time.
7 years ago
Is the cable securely plug into the back of the monitor and the PC? If you shine a flash light at the monitor and look vary closely do you see an image?
Typically the first thing to go bad in a monitor is the back lighting. Is this an LED backlight or just a regular LCD montior?
Answer 7 years ago
it's a led moniter, and it displays it displays the logo of dell(its a dell moniter) after i turn it on, but doesn't display the things it should display next..
Answer 7 years ago
Then try unplugging and replugging in the video cable to the monitor and the PC to make sure it's seated correctly. If the monitor has both a VGA, DVI and/or HDMI then go into the monitor's menue and make sure the correct input is selected.
Does teh PC give off any beeps when it is first turned on? IF it's more than one beep in any sort of pattern that indicates a problem with the system.
7 years ago
Did this monitor work before ?
Answer 7 years ago
it worked absolutely fine.
7 years ago
I thing there is a problem create on it's power supply. You just change the power supply of your monitor then watch.
