6818Views6Replies
Author Options:
WiFi Repeater with Arduino? Answered
Would it be possible to make a WiFi repeater with the equipment on this Instructable: https://www.instructables.com/id/LINUX-LEECH/ withe the addition of Arduino and a small LCD? It would be really awesome and may even lead onto cheap mesh networking! :D
Thanks for any help! :)
steveastrouk
steveastrouk
Best Answer 10 years ago
Yes, it can be done, and probably for less than the cost of the bits used in the original project
You need a DG834 Netgear router or similar.
https://forum.openwrt.org/viewtopic.php?id=23705
The "OpenWRT" linux platform is used to do lots of clever things with old routers....
Steve
steveastrouk
steveastrouk
Answer 10 years ago
PS. Google on "Wi-fi repeater openwrt" for more ideas.
It will still be a low cost solution.
Steve
skaar
skaar
9 years ago
you can probably use a zigbee module and arduino as a finished item, everything's changed, some arduino's have ethernet and usb, as well as enough space for the stack wifi needs.
steveastrouk
steveastrouk
10 years ago
No, an arduino can't handle the USB, and can't handle Linux ?
Steve
Sev the Sniper
Sev the Sniper
Answer 9 years ago
Thanks for the assistance Steve =)
Sev the Sniper
Sev the Sniper
Answer 10 years ago
Ohh ok, thanks for your reply, I just wondered because of what Bay Fielder said:
"I like this project very much! I personally see it as part of a larger project...
If you ad this to a micro computer it's great. They usually only have one or two USB ports, and have a case about the same size as this project. Some have VESA mounting holes that you can (if you measure for it) mount this project to. If you increase the available mAh of the power supply, and add a second USB WLAN... you can use it as a relay. Put this box where you can get the signal well, and have it rebroadcast --use it as a repeater. It may help to use a 3-5ft USB male to female to keep the two WLAN nics apart.
There are Linux distros that can do this... somebody will share a link I'm sure.
Add a LCD screen (projects right here on this very site) that can show you a few lines of txt, and a few buttons (borrow a project from a M.A.M.E. cabinet) and you could make it select a network (and allow you to enter WEP/WPA/WPA2 key). Now you got a self sufficient WLAN relay, to use in any legal, or illegal way the end user wishes."
Would there be any alternative way of doing this? Thanks
