123Views6Replies
Wifi Router to Wifi Router Comms?
Hi all,
i have my Main Wifi router Netgear Wndr4500 and i want to use it to talk to my old Dlink 2730b so i can use the LAN ports on the Dlink.
PayTvBox > DLINK --<WIFI>--Netgear-->internet
i can't use Powerline Ethernet because the surge boards muck with it.
Best Answer 7 years ago
If your DLINK has a client mode it should work....I couldn´t find the manual on the D-Link website....
I used a TL-WA500G from TP-LINK for a similar setup (PC instead of a PayTvBox) and it worked fine...
Answer 7 years ago
would this one work TP-Link TL-WA701ND
it has AP-Client mode
Answer 7 years ago
yes, almost certainly!
7 years ago
So your wanting to convert the old router into a wireless hub. Not really something they can do. You can make it an access pint, repeater or bridge but they only make use of the wifi of the old router. The Ethernet ports are not usable to connect to the network over wifi. If you want to add PC's to a wireless connection then get a USB Wifi dongle for them.
Answer 7 years ago
i want to connect devices that don't have the ability to have USB dongle but have an Ethernet port.
is there a model of router that can do it? or is there a specialized device?
Answer 7 years ago
There are boxes you can buy called print servers. The offer up a USB port for your printer to connect to and link it up to your wifi network. Here is one for around $40.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833139028
