330Views15Replies
Author Options:
Will .22 lead slugs work in a ball mill in place of ball bearings? Answered
I'm making a ball mill but am having trouble acquiring lead ball bearings.
Burf
Burf
9 years ago
Forget the lead, go down to your local hardware store and purchase a box or two of brass nuts. Depending on the size, you can get a box of 100 for less than $10 U.S.
Its going to be much cheaper and definitely easier and safer than trying to pull the slugs from a couple of boxes of .22 bullets.
WareOuttaHair
WareOuttaHair
Answer 9 years ago
By .22 slugs I meant pellets from my .22 caliber airrifle
caarntedd
caarntedd
Answer 9 years ago
You can buy the projectiles as a separate item.
baudeagle
baudeagle
9 years ago
Why would you want to use lead in a ball mill? This does not make a lot of sense. Using lead balls the lead will abrade away because it is soft and probably not accomplish what you are hoping for. In addition lead is not very healthy to work with especially if it is broken down into a fine powder. Rather than lead ball I would recommend alternatives such as, steel bb's, steel marbles or glass marbles. The balls in a ball mill needs to be harder than the material it is processing.
Although 0.22 lead slugs might work for your application, if you really want to use lead balls you might also try these alternatives: 50 cal black powder slugs or fishing weights.
frollard
frollard
Answer 9 years ago
Only trouble is lead is soft enough to gently pulverize chemicals like gunpowder, while steel is so hard it will act more like a pair of hammers and ignite the mixture.
RavingMadStudios
RavingMadStudios
Answer 9 years ago
+1
Generally, I prefer a non-asplodey workshop.
NachoMahma
NachoMahma
Answer 9 years ago
. Gee. You're no fun.
RavingMadStudios
RavingMadStudios
Answer 9 years ago
I know... I'm a total killjoy.
frollard
frollard
Answer 9 years ago
My co-worker was telling me of a local chemical factory where the operator intentionally committed suicide by throwing a bucket of steel shot into the open-top ball mill while it was running. Very splodey + shrapnelly.
steveastrouk
steveastrouk
9 years ago
Brass or copper are also non-sparking metals, I think they'd work well too.
Stvee
RavingMadStudios
RavingMadStudios
9 years ago
Try the fishing section of a sporting goods store. Sinkers and split shot line weights are available in both lead and lead-free varieties in several sizes.
orksecurity
orksecurity
9 years ago
Suggestion: Get an auto restoration supplies catalog. Car rebuilders use ball mills to polish restored or handmade parts. Those catalogs usually offer a variety of media in varying degrees of hardness... and unlike lead, they won't give you heavy-metal poisoning.
rickharris
rickharris
9 years ago
Too soft - you might try metal BBs
