523Views6Replies
Will a transformer that outputs 6000 volts work for a Jacob's Ladder?
I've been looking on ebay to find a transformer to use for a Jacob's ladder, and there seem to be a lot that output 6000 volts, and they are at a price that I am willing to pay. So, will 6000 volts be enough to use in a Jacob's ladder? If anyone could answer this, that would be swell. Thanks.
Best Answer 11 years ago
Yes, it will work. The gap at the bottom will just have to be a little closer than normal.
@steveastrouk: I believe it is 10kV per cm, which is around 30kV per inch
11 years ago
6kV is a bit low. You need 30kV to flash over a 1cm gap. You can use some tricks to double voltage, but I am not sure how much current you need for a successful device, and you need some very high voltage components to make the doubler with !
Answer 11 years ago
how do you double the voltage? I have a small tesla coil that I connected to a 220 volt tranformer and it sucked every drop of the 220 V. No streamers came out, tthough
Answer 11 years ago
What was your circuit ?
Answer 11 years ago
^ A. H. Howatson, "An Introduction to Gas Discharges", Pergamom Press, Oxford, 1965, no ISBN - page 67
The dielectric breakdown strength of dry air, at Standard Temperature and Pressure (STP), between spherical electrodes is approximately 33 kV/cm.
Answer 11 years ago
To flash over. I'm using a Microwave oven transformer (~2000v ~500mA) and it can arc over a 7cm gap if there isn't wind, you just need to touch the terminals together to start the arc...
