2635Views6Replies
Author Options:
Will glass marbles cause static electricity when used in a ball mill to grind black powder? Answered
Will glass marbles cause static electricity when used in a ball mill to grind black powder? it's for a homemade ball mill.
binder113
4 years ago
significant static electricity is generated when rubbing two dissimilar materials together if they are far apart on the triboelectric series:
http://en.wikipedia.org/wiki/Triboelectric_effect
the list shows that glass is on the positive side, so any material far on the negative side such as ebonite or gold will cause charge seperation and static electricity.
Glass rollers can be used in vandergraph generators to build a massive charge.
I assume this mill is home made, and an immediate concern is if you are using a PVC container for the marbles. Charge build up is likely to accumulate between these materials.
if the material being milled is conductive, no charge build up will occur
nutsandbolts_64
9 years ago
Most definitely not! My friend used marbles to grind matches into dust! And he's not dead, nor is he in the hospital. So yeah, I guess it's pretty safe.
Evilblaze
10 years ago
Glass cause static electicity? No. Of course no. But it is better if you use lead, because it is much more heavier.
5150tech
10 years ago
I don't know if glass will generate a charge but other insulators do. a balloon is an insulator but it can generate and discharge electricity. I would proceed cautiously.
lemonie
10 years ago
I don't think so. But it's usually best to grind black powder damp then dry it out.
L
fwjs28lemonie
Answer 10 years ago
same thoughts here, glass is an insulator, so it should'nt ....but to be safe moisten the black powder
