355Views1Replies
Will these LEDs work in my computer case?
I want to change my standard blue LEDs to color changing LEDs and I was wondering if there is any modification I have to do to the wiring. The LEDs I have now are 5mm and I am going to replace them with 5mm color changing and I dont want to ruin my power supply.
Best Answer 12 years ago
size wise, you will be fine. you need to make sure that the new leds are able to handle 5 or 12 volts if you are wiring straight to a molex connector, or whatever the output voltage is if it going to be wired to an inverter board. Otherwise the leds will fit in the holes correctly and assuming the new leds only have 1 anode and 1 cathode, then the wiring will be the same also. If you have anymore questions, don't hesitate to ask.
