110Views26Replies
Author Options:
Windows XP Answered
Hello, I am one of the benefidiary of your site wherein i get lot of replies to solve my computer problems. Now i have a problem.Kindly help me out. I have downloaded some music file and stored in a folder. I wanted to delete the folder, but it says access denied. When i saw the properties it shows the file is read only. How to delete this folder. Similarly i have zip file it is also not being deleted. Kindly advice. regards, Balatv
ich bin ein pyro
ich bin ein pyro
13 years ago
and why is it that you want to delete this file anyway? what i would do is delete every song and if they cannot be deleted, hide it but that only works if you want it deleted for memory not for hiding.
balatv44
balatv44
Reply 13 years ago
Thank you for the prompt reply and your advice. I just wanted to delete the file. When i could not delete it, i sought your help. This is the first time i am experiencing this sort of problem. Any how i got the answer through highly knowledgable forum. This fourm is always giving quick and correct solution to solve my problems. Pl continue your good work.
its a lion
its a lion
Reply 13 years ago
out of curiosity, what was wrong and how did you fix it?
balatv44
balatv44
Reply 13 years ago
Hello, Let me explain. I used to download songs from the net and store it in the pce in different folder according to the singer. I moved these songs from the folder to a different location. But it did not move to a new folder. When i wanted to open the original folder, it was opening stating that the access denied. To my surprise only one song used to play in the windows media player. So I wanted to delete the folder. As i could not delete, i sought the help of this forum.I Used KillBox software and deleted the cntents but not the folder name from the pc. First i renamed to a small name and deleted it. Let me thank this forum once again.
chooseausername
chooseausername
13 years ago
Unless there is a special restriction somewhere (files stored into a folder that belongs to an other user for instance), it should be possible to remove the "read only" protection of your files. If you're under Windows, you right-click on your files, select "properties", and look somewhere there to un-check the "read only" checkbox.
balatv44
balatv44
Reply 13 years ago
Thank for the quick reply. I tried to change the attributes. When i press the apply button it is ok, but again it changes to read only file. That was my problem.
gyromild
gyromild
Reply 13 years ago
Have you solve the problem? If the case is read-only keeps appearing, then I'm almost certain it's a problem with NTFS permission entry.
1) Disable Simple File Sharing:
- Open any folder
- Then go to Tool > Folder Options > View > Advanced Settings > Use Simple File Sharing
- Un-check it
2) Then:
- Right click on the folder and go to Sharing and Security > Security
- Click on your username, and check the box to allow Full Control under permission.
- Click OK, and try deleting the folder.
3) If that doesn't work, then you're going to have to remove the Inherited permission entry
- Right click on the folder and go to Sharing and Security > Security > Advanced
- Un-check the box Inherit from parent permission entry...
- Click Copy when prompted.
- Choose your username from the list, and click Edit
- Under Permission, again check to allow Full Control
4) If that still doesn't work, then it could possibly be a physical problem on your hard drive sector where the folder reside. Not much you can do here except buying a new hard drive :(
gyromild
gyromild
13 years ago
1) Try deleting them using KillBox. I would suggest you use the Delete On Reboot option.
2) Or if you have administrator privileges, you can try:
- Right click and choose Sharing and Security.
- Click on your username, and check the box Allow Full Control
- Click OK, and try deleting them.
balatv44
balatv44
Reply 13 years ago
Thank you for the immediate reply. I used this software. before that i have rename to a shorter name and deleted the file on reboot. I could remove the contents but not the folder itself. The folder isempty and still in the pc.
libertyshouts
libertyshouts
Reply 13 years ago
can answer to my prob. From where I can download vista theme
libertyshouts
libertyshouts
13 years ago
Hello do anyone hve answer to my prob. From where I can download vista theme
Punkguyta
Punkguyta
13 years ago
Is it just me guys or did this guy tell us that we're going to help him. To the newbie (Seriously that's what you are): By chance are these "music" files on a non-rewrite-able cd/dvd? Folders do not just change their own permissions by themselves. If it's not deleting your filesystem is probably corrupt.
NachoMahma
NachoMahma
Reply 13 years ago
> did this guy tell us that we're going to help him . I'm guessing that English is not balatv44's first language. I don't think he was trying to tell us to do anything, just worded his request a bit awkwardly. Judging by his responses in this thread, he is polite to a fault. . > Folders do not just change their own permissions by themselves . It is not uncommon, especially after a crash, to have files left open (if a file in a folder is open, you can't delete the folder). That's why ppl went to the trouble of writing utils such as KillBox and Unlocker. ;)
balatv44
balatv44
Reply 13 years ago
In my reply i only expressed my sincere thanks for the reply you hve given to my problem. In case it looked otherwise, I am sorry for this and i regret vey much. Earlier on many occassion i sued to get help from this august forum. If my english hurts any one i will withdraw my thread and assure you i will never come with the problem to this forum. Thank you for pointing out and with regards.
Punkguyta
Punkguyta
Reply 13 years ago
It's okay my man, hopefully your time on instructables will help you learn a few more words and get the hang of english, it's a great thing, and one of the most complicated languages.
Punkguyta
Punkguyta
Reply 13 years ago
Windows :p I've only had a problem with that with my mac once and all it took was a restart and I could delete the file.
balatv44
balatv44
Reply 13 years ago
I downloaded this file from a site.All other files which were downloaded could be deleted. The problem was i moved this file to a different location. Afterwards i wanted to delete the file. I could not delete this file. That is why i posed this problem.
balatv44
balatv44
13 years ago
Hi, Thank you very much for your prompt reply . I could delete the file. Thanks again. I hve one more problem with windows XP. I hve installed windows xp pro home edition. It is in the C dirve. When i saw this drive in windows folder, it shows the total MB in this folder shown as 20GB. I feel tht this much space occupation by windows software looks on the high side. How to check this. I dont want to meddle with the software. Pl advice. regards,
libertyshouts
libertyshouts
Reply 13 years ago
I think you should check the other drives. If, they have very less GB space. That means the sharing of your space is not proper.
NachoMahma
NachoMahma
Reply 13 years ago
. I'm only showing 3.5GB in my WinXP Pro directory, but I've deleted a bunch of stuff (although I seriously doubt it was 16+GB). Try right-clicking on the WINDOWS folder and select Properties.
libertyshouts
libertyshouts
Reply 13 years ago
libertyshouts
libertyshouts
13 years ago
I think you should change the attribute to any other expect read only Want video..????
balatv44
balatv44
Reply 13 years ago
Thank you very much for your promt reply. I could arrest the problems.
balatv44
balatv44
Reply 13 years ago
Thank you very much for your reply. You are always come to my rescue to solve my problems.
