138Views3Replies
Author Options:
Wireless water level indicator? Answered
I have a tank that's above my 2 story house. I did use a 50 foot Ethernet cable and wire up a level indicator, with 5 levels from empty to full. But the wires always corroded, and it just stopped working. What i'am looking for is a way, to do the same wirelessly. Maybe even automate via ifttt, as my motor is connected to a smart plug the HS100. How can i accomplish this, the tank is open to the elements, so something waterproof, and solar/battery operated would be great. I did think of the Xiaomi Water sensor, which generally checks for dampness,but that needs a Xiaomi gateway, so what does the community suggest?
ggom20
ggom20
2 years ago
Hello!
Your previous system looks great, with it' 5 levels of measurment.
Think about electronics in a submarine .
Why not try a sealed plastic enclosure for those connections.
They are easy to find , not expensive at all.
When finished and tested the system,
seal it at cable bypasses, cover, screws, everywhere with a
silicon sealer, you can also put in some silica-gel in a little container
that will absorb any residual moisture.
Regards
