337Views5Replies
Wiring 5 4pdt toggle switches (using center & 1 outside row contacts) 1 on cuts power off to others?
5 4pdt switches using only center & 1 outside row of terminals (8 connections per switch). Power (9vdc) in to 2 terminals on center row each switch. When turn any one switch on, want other 4 disconnected from power. Don't want anything programable. Relays ok or an ic. Trying to keep it basic & reasonable. Using total of 10 4pdt switches, half negative side & half positive voltage. Set-up to work on either bank of switches. More switches or 6pole not an option because of expense. I can come off 1 terminal with power to ????? I feel like I'm missing something simple. I hope somebody reading Instructables has a solution. Thanks in advance for your help.
8 years ago
Are these centre off switches ?
Answer 8 years ago
No, they are on-on switches
Answer 8 years ago
So there isn't an "off", only that the +ve voltage won't be switched in
Answer 8 years ago
I want to flip one switch to make all four contacts on it & disconnect power to other 4 switches. Example 5 switches wired to 5 lights, ABCD&E. Switch C turns on light C only but keeps ABD&E from turning on any lights.
Answer 8 years ago
Use logic chips.
Then you have to implement the following logic table.
Aout = A./B./C./D
Bout=/A.B./C./D
Cout=/A./B.C./D
Dout=/A./B./C.D
Where the . means "AND", and the / means negate. Its pretty simple to do with 4000 series gates, the 4082 is a 4 input AND, and 4069 inverters.
You need only single pole switches.
