338Views10Replies
Author Options:
Would I be able to put one 100 ohm 1/4 watt resistor in place of two 50 ohm 1/4 watt resistors? Answered
The attached picture explains my question a little better. Thank you guys!
arfon
arfon
Best Answer 6 years ago
No, they are in parallel so the resistance should be 25 Ohms. Also, there are two 1/4W resistors so, you should use a 1/2W resistor.
Jakester98
Jakester98
Answer 6 years ago
Perfect! Thank you very much!
So, with that in mind, does this mean i could put a 10-15 Ohm 1W resistor on 4 LEDs?
arfon
arfon
Answer 6 years ago
Let's do the math... R = 1/( 1/50 +1/50 + 1/50 +1/50)
=1/( .02+.02+.02+.02) = 1/(.08) = 12.5 Ohms
so, you could replace all four resistors with a 12.5 Ohm resistor.
Power would be 1 * 1/4W = 1W
So, you could use one 12.5 Ohm 1W resistor to replace all 4
arfon
arfon
Answer 6 years ago
CORRECTION: Power would be 4* 1/4W = 1W (I got ahead of myself went typing the above)
verence
verence
Answer 6 years ago
If you have really no other option... you may try. If x is the number of parallel diodes: 50Ohm/x, 0.25W*x.
BUT: You should not do that. LEDs have minor differences. If you put them on a shared resistor, one with (the slightly lower Uf) will get more current than the other(s). The results may vary from not even being noticeable to a thermal run away and break down of the LEDs.
So it may work but is not recommended.
steveastrouk
steveastrouk
Answer 6 years ago
No, you need to use 50Ohm resistors. Or you need 5 X 10 Ohm resistors, which can be 1/5th Watt.
arfon
arfon
Answer 6 years ago
FYI, to calculate the total resistance of paralleled resistors, the formula is:
arfon
arfon
6 years ago
When putting resistors in series, you just add the values to get the total resistance. When putting resistance is parallel, you add the CONDUCTANCE (1/R) and then convert back to resistance.
iceng
iceng
Answer 6 years ago
If they are the same ...... Just divide by the number of them !
arfon
arfon
Answer 6 years ago
Yes, but I wanted to show the proper way of calculating them so when he runs into different values...
iceng
iceng
Answer 6 years ago
And you did it very well.
Fifty years after graduation, the number of times Iv had to work uneven parallel resistors is counted on one hand.....
iceng
iceng
6 years ago
Paralleling LEDs taken to the extreme just one resistor used here see the brightness variations on hand test selected LEDs !!!!
