15425Views13Replies
Author Options:
Would it be possible to mix titanium and steel? Answered
Theoretically, could it be possible to mix titanium and steel and get the best of both? Let’s just assume that cost and difficulty are not an issue? Imagine the possible uses for a metal that was non-magnetic, non-conductive, corrosion resistant, and with a great strength to weight ratio, while being as hard as tempered steel. For one thing, it make a fantistic knife.
So, the question is;
Would it be possible.
bwrussell
bwrussell
Best Answer 9 years ago
That's not how material science works. You don't just mix two or more metals together and get the best out of each base metal. It's a give and take. With high strength comes brittleness, with good ductility comes weakness, etc, etc. Everything you described is basically Ti, adding the steel just lowers your strength-to-weight ratio.
black hole
black hole
Answer 9 years ago
Okay, thanks for a nice clear answer. Now that I think about it, the question was kind of dumb. After I read your answer, I had one of those "Why didn't I think of that" moments.
ZyphroR
ZyphroR
2 years ago
Titanium + diamond + carbon + composit armor =??????
richer21
richer21
Reply 6 months ago
that wouldn't work becasue composit armor is just layers of armor.
RitinP
RitinP
3 years ago
When we should this metal in the same mixture and v maintain a constant but high temperature to maintain this process
RitinP
RitinP
3 years ago
We should mix Titanium in 2.5 kg and Platinum 5.6 kg and then we should make Carbon Steel in the ratio of 3.5 kg then it is maybe possible to make a new Unbreakable metal
EmanueleS1
EmanueleS1
5 years ago
Hey I'm a beginning knife maker and i'd like to know from you guys if Titanium could be used as a blade material? Because it's so strong, corrosion resistant, non magnetic etc.... And can Titanium be heat treated?
pgriffith2
pgriffith2
7 years ago
http://www.chasealloys.co.uk/steel/alloying-elements-in-steel/
Essentially, it's mixed with carbon steel in low levels to provide grain (microstructural) stability. Adding iron straight to Ti (or vice-versa) would result in a very brittle, rather useless mess.
iceng
iceng
9 years ago
Welding tips are titanium and conduct heavy electric current to a metal weld.
steveastrouk
steveastrouk
Answer 9 years ago
Welding tips are tungsten IME.
Steve
iceng
iceng
Answer 9 years ago
Darn, I'm getting old....
Only just this moment did I recall Titanium is used in aircraft and turbine flywheel rims.
It "Titanium" is a metal that comes from Russia in 50 gal drums in
a form called "sponge"  see pic and is arc melted into great ingots
in a 20 foot tall O2 free furnace.
Discovered in your Cornwall by William Gregor. It is the highest strength
to weight ratio of any metal, it is used in space craft and jet engines...
Titanium is as strong as some steels but 45% lighter and a poor
conductor of electricity which I read.
Alex
Vyger
Vyger
9 years ago
Read the Wikipedia article on it
http://en.wikipedia.org/wiki/Titanium
Titanium can be alloyed with iron, aluminium, vanadium, molybdenum, among other elements, to produce strong lightweight alloys for aerospace (jet engines, missiles, and spacecraft), military, industrial process (chemicals and petro-chemicals, desalination plants, pulp, and paper), automotive, agri-food, medical prostheses, orthopedic implants, dental and endodontic instruments and files, dental implants, sporting goods, jewelry, mobile phones, and other applications.[2]
The two most useful properties of the metal form are corrosion resistance and the highest strength-to-weight ratio of any metal.[5] In its unalloyed condition, titanium is as strong as some steels, but 45% lighter.[6] There are two allotropic forms[7] and five naturally occurring isotopes of this element, 46Ti through 50Ti, with 48Ti being the most abundant (73.8%).[8] Titanium's properties are chemically and physically similar to zirconium, because both of them have the same number of valence electrons and are in the same group in the periodic table.
SOOO- Titanium is already alloyed with IRON, not steal as Steve brought out, which is already an alloy.
steveastrouk
steveastrouk
9 years ago
No, because "steel" isn't a metal, its a solid solution of iron and carbon. Does ferro-titanium exist ? yes, but its not got any of the desirable properties of your proposed alloy. Its used to clean steel, because the titanium is extremely reactive
Where do you get the idea that titanium is non-conductive ?
