296Views5Replies
Author Options:
Would this work as an XOR logic gate? Answered
Hi, I'm new to logic gates and I am wondering if this would work as (or is) a XOR logic gate.
steveastrouk
steveastrouk
Best Answer 9 years ago
L.'s reply to Sean applies to the transistor too..
In the first case, when A=0 B=0 then the output of the OR gate is 0 and the output of the NAND gate is 1, there is 5V on the base and 0 V on the collector. This is an NPN transistor, so there is a forward biased diode between +5 and 0V. Smoke.
Steve
josh1324
josh1324
Answer 9 years ago
Thanks alot! :D
lemonie
lemonie
9 years ago
That's a OR and a NAND?
Where are your truth tables? (that's how I figured it out...)
If this is correct, yes it should do an EX-OR. But why not connect the outputs to the same leg of the transistor?
L
seandogue
seandogue
Answer 9 years ago
lemonie, for an answer to why-not?, examine the case where a=b=0 or a=b=1. smoke
lemonie
lemonie
Answer 9 years ago
The outputs will be 1 or 0, high or low (and equally so). As semiconductors I'd expect a diode-functionality in them, so I don't see a problem myself.
L
