162Views0Replies
Author Options:
Write output on registery inside ESP8266 Answered
Could any one help me please?
I have the following code to make MODBUS tcp/ip(its work good) the other issue in the code is ultrasonic sensor (trig on D1& echo on D2 and output distance on serial port)I want to write distance on one of memory register say (3). I use the command "digitalWrite(distance, MBHoldingRegister[3] )" its fail then I use analogWrite also fail what's the solution?
#include
#define trigPin D1
#define echoPin D2
#define analog_output D5
float distance;
long duration;
int dataIn;
int m = 0;
int h = 0;
int t = 0;
const char* ssid = "MH_Ext";
const char* password = "74375325";
int ModbusTCP_port = 502;
//////// Required for Modbus TCP / IP /// Requerido para Modbus TCP/IP /////////
#define maxInputRegister 20
#define maxHoldingRegister 20
#define MB_FC_NONE 0
#define MB_FC_READ_REGISTERS 3 //implemented
#define MB_FC_WRITE_REGISTER 6 //implemented
#define MB_FC_WRITE_MULTIPLE_REGISTERS 16 //implemented
/ MODBUS Error Codes
#define MB_EC_NONE 0
#define MB_EC_ILLEGAL_FUNCTION 1
#define MB_EC_ILLEGAL_DATA_ADDRESS 2
#define MB_EC_ILLEGAL_DATA_VALUE 3
#define MB_EC_SLAVE_DEVICE_FAILURE 4
/ MODBUS MBAP offsets
#define MB_TCP_TID 0
#define MB_TCP_PID 2
#define MB_TCP_LEN 4
#define MB_TCP_UID 6
#define MB_TCP_FUNC 7
#define MB_TCP_REGISTER_START 8
#define MB_TCP_REGISTER_NUMBER 10
byte ByteArray[260];
unsigned int MBHoldingRegister[maxHoldingRegister];
WiFiServer MBServer(ModbusTCP_port);
void setup() {
pinMode(14, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
Serial.begin(9600);
delay(100) ;
WiFi.begin(ssid, password);
delay(100) ;
Serial.println(".");
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
MBServer.begin();
Serial.println("Connected ");
Serial.print("ESP8266 Slave Modbus TCP/IP ");
Serial.print(WiFi.localIP());
Serial.print(":");
Serial.println(String(ModbusTCP_port));
Serial.println("Modbus TCP/IP Online");
void loop() {
distance = getDistance();
Serial.println(distance);
delay(1000);
// Check if a client has connected // Modbus TCP/IP
WiFiClient client = MBServer.available();
if (!client) {
return;
boolean flagClientConnected = 0;
byte byteFN = MB_FC_NONE;
int Start;
int WordDataLength;
int ByteDataLength;
int MessageLength;
// Modbus TCP/IP
while (client.connected()) {
if(client.available())
flagClientConnected = 1;
int i = 0;
while(client.available())
ByteArray[i] = client.read();
i++;
client.flush();
///// code here --- codigo aqui
///////// Holding Register [0] A [9] = 10 Holding Registers Escritura
///////// Holding Register [0] A [9] = 10 Holding Registers Writing
/// Enable Output 14
digitalWrite(14, MBHoldingRegister[14] );
digitalWrite(distance, MBHoldingRegister[12] );
//// end code - fin
//// rutine Modbus TCP
byteFN = ByteArray[MB_TCP_FUNC];
Start = word(ByteArray[MB_TCP_REGISTER_START],ByteArray[MB_TCP_REGISTER_START+1]);
WordDataLength = word(ByteArray[MB_TCP_REGISTER_NUMBER],ByteArray[MB_TCP_REGISTER_NUMBER+1]);
// Handle request
switch(byteFN) {
case MB_FC_NONE:
break;
case MB_FC_READ_REGISTERS: // 03 Read Holding Registers
ByteDataLength = WordDataLength * 2;
ByteArray[5] = ByteDataLength + 3; //Number of bytes after this one.
ByteArray[8] = ByteDataLength; //Number of bytes after this one (or number of bytes of data).
for(int i = 0; i < WordDataLength; i++)
ByteArray[ 9 + i * 2] = highByte(MBHoldingRegister[Start + i]);
ByteArray[10 + i * 2] = lowByte(MBHoldingRegister[Start + i]);
MessageLength = ByteDataLength + 9;
client.write((const uint8_t *)ByteArray,MessageLength);
break;
case MB_FC_WRITE_REGISTER: // 06 Write Holding Register
MBHoldingRegister[Start] = word(ByteArray[MB_TCP_REGISTER_NUMBER],ByteArray[MB_TCP_REGISTER_NUMBER+1]);
ByteArray[5] = 6; //Number of bytes after this one.
MessageLength = 12;
break;
case MB_FC_WRITE_MULTIPLE_REGISTERS: //16 Write Holding Registers
MBHoldingRegister[Start + i] = word(ByteArray[ 13 + i * 2],ByteArray[14 + i * 2]);
MessageLength = 12;
break;
//===== getDistance - Custom Function
int getDistance() {
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance = duration * 0.034 / 2; // distance in cm
return distance;
