64887Views16Replies
Author Options:
XP "Classic" search in Windows 7? Answered
It took a lot to make me change from XP, but I do like Windows 7 which I'm now running on a couple of machines.   However . . .
The thing I miss is the 'classic' explorer search function which gave a no-nonsense way of finding any set of files on your computer (indexed or not) with proper wildcarding and various other settable criteria.
OK, Microsoft search V4 (or whatever it's called) has all sorts of bells and whistles, but I'm finding it unwieldy to use and find myself opening a DOS box for speed.
Google finds a lot of posts from other people who liked the old search, but no answers.
Has anyone here found a utility which replicates the old search functionality?
lolwatumad
lolwatumad
Best Answer 9 years ago
FileSearchEX is the perfect alternative to the Windows 7 search (or lack of) interface. It's almost exactly like the classic XP search window, minus that stupid dog. Just make sure you run the registry alteration (the .REG files) so that it gets applied to the right search menu and what not.
http://goffconcepts.com/products/filesearchex/
The most similar Windows 7 method to classic XP is to right-click a folder, select 'Open in new window', and then use the search bar in the upper-right corner. But that way is large, clunky (just 14 files & folders take up the whole screen), and I can't find an easy way to search just files names or just a word in a file.
AndyGadget
AndyGadget
Answer 9 years ago
The answer was a long time coming (18 months) but that's the one!
Just what I was looking for - Many thanks.
jaylweb
jaylweb
Answer 7 years ago
Actually, you had this very same suggestion by pcunite in just over a month from the creation of this topic.
AndyGadget
AndyGadget
Answer 7 years ago
 . . . and another two years for you to post this comment. How time flies #;¬)
Nowadays I use Agent Ransack which is better than anything else I've come across.
PhilippT
PhilippT
6 years ago
Well another alternative could be using a third party windows search tool like Lookeen.
http://www.lookeen.com
Best Regards
PhilippT
AndyGadget
AndyGadget
Answer 6 years ago
The download is a 14 day trial - I went no further.
I've been using Agent Ransack for a couple of years now. It's totally free and the best search utility I've come across.
pcunite
pcunite
11 years ago
Yes I am using one! It is called FileSearchEX and it works like a champ. classic search for Windows 7 is here baby! Now does anyone know how to get the UP button for folders? goffconcepts.com/products/filesearchex
snakelips
snakelips
Answer 10 years ago
Regarding the UP button, check out Classic Shell (http://classicshell.sourceforge.net/gallery.html). It puts the up button back, along with restoring a great number of other XP features that seem to have been deleted or hidden in Windows 7. -snakelips
daniel.kavalera
daniel.kavalera
Answer 6 years ago
thas right the Classic Shell, restores a lot of functions thar used to work just fine in the past, like the classic Star Menu and the UP button for folders. and it has many many other functions that can be customized too
Gregorid
Gregorid
6 years ago
Also in Windows XP with classic search engine you can made small changes which will made that your files instant jump in results without usual waiting like that is case when you try to find some file/folder. Here you have info how to set that > http://pc-problem-solutions.blogspot.com/2013/10/make-windows-xp-file-search-faster.html
MelchiorG
MelchiorG
Answer 6 years ago
COOL! just checked out your SourceForge page...
CAN SEARCH MULTIPLE directories at the same time.!
THAT MADE MY DAY!! ^_^
AndyGadget
AndyGadget
Answer 6 years ago
Since I posted that question I've discovered Agent Ransack which does everything I want (and more), but I'll try your utility - Many thanks.
(And the absence of animated mammals is always a good thing in a search engine ;¬)
MahavishnuMan
MahavishnuMan
11 years ago
Well, the search is there - in any explorer window you open.  Go into My Computer, and look in the upper-right corner; you'll see the search.  To my knowledge, I believe it bases its search on the settings you have in Folder Options under Control Panel (with regards to searching hidden files and folders, system folders, &c.).
dferris
dferris
Answer 8 years ago
I think the issue is we'd like for ao fht customized choices we used to have in older versions of windows. Such as find all music on a drive before you blow it out. I don't want to do 9 different searches based upon file extensions. Same for videos.
USvet
USvet
9 years ago
Thanks for the heads up. Actually I like the Dog in the XP search. It's a shame when they ""upgrade" things they don't ask what we like and dislike before they throw the baby out with the bath water! Thanks again.
Avadhut.Deshmukh
Avadhut.Deshmukh
9 years ago
http://windows.microsoft.com/en-us/windows7/products/features/windows-search
http://www.zdnet.com/blog/btl/create-a-windows-xp-classic-start-menu-in-windows-7/46158
markinboone
markinboone
10 years ago
In Win7 there's no UP button because you can click on the folder in the path at the top to go to that folder. So if you're in C:\Users\Default\Desktop you can click on Default in the path to go UP to that folder. Click on Users to go up 2 folders. It's actually a little easier if you get used to it. Want to go to a different folder that's on the same level as the one you're in? (up one, down another)... hold your mouse over a folder name in the address bar and all its subfolders are listed. Take your pick.
AndyGadget
AndyGadget
11 years ago
I'll take that as a 'no' then.
