Your Best Trick!
Hi Guys ^.^
Just wondering what is your best trick? hardest trick? and how you do it? Everyone has different techniques so your way could help others do the trick... :)
My best / favourite / hardest trick is a triple K-flip into dark slide shuv-it into 5-0 grind with an impossible out.
The K-flip I do like a normal kick flip but pop higher / kick harder, also one has to catch it before it makes the 4th revolution. The shuv-it is tricky as it goes 270degrees and 1/2 a flip, fingers go in the center and just behind and under 1 back wheel. Catch it and land manual on the rail then set up for a back foot impossible. Fingers like a K-flip but the back finger more to the toe side so as to hook/pull the board round. Pop hard and swing the back finger upwards while at the same time moving the front finger out the way, as the board comes back round catch with the front finger and land it.
Hope it helps anyone stuck with those tricks. Now I want to hear from you! =D
Mountain Island xx
