advice sought with connections on power booster
Hi, could i ask you for advice as i want to know how to correctly wire a small 6v to 12v power booster to my moped that has a 6v electrical system. I need to use this tiny booster to charge my phone via a 12v phone charger. there is no intrustions with the booster but i suppose it goes as follows. please give me input about it so i won't blow it up before i connect it.
so only using the red possative wire leading from the bikes battery to connect the phone charger!
Tthe booster has a possative + in and possative out + and ground connection. shall i connect the possative in to my bikes red possative wire running from its battery and then connect the possative + out connection to the phone charger and also run a wire from ground to the bikes chissis. does that sound about right to you. please let me know.
Thanks.
http://www.ebay.co.uk/itm/350436684000?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
9 years ago
Assuming the moped is negative ground, you are correct that:
In+ goes to the positive terminal of the battery
Out+ goes to the positive side of the charger
Gnd goes to the chassis/negative terminal of the battery
The negative side of the charger also goes to the chassis.
