78Views4Replies
Author Options:
am intrested in making my first solar panel.where can i get the materials and at what price.can somebody help? Answered
eager to construct a 40 watt at fist.in need of price list of materials needed and a manual to follow.thanks in advance
Tags:solar
jj.inc
7 years ago
Buy a one or more 12 volt deep cycle marine or RV batteries: http://www.summitracing.com/parts/ULT-9016-103
Get a solar panel and a charge controller:
http://www.amazon.com/HQRP-Monocrystalline-Controller-Regulator-Possibility/dp/B003SG2AY2
Your done, if you wan't to get 120v out of it get one of these:
http://www.amazon.com/Whistler-Pro-100W-Watt-Power-Inverter/dp/B003R7IDTI
All of this comes out around 400 dollars. Setup should be easy especially with the recommended kit, and if you know red (+) black(-) then you are set.
seandogue
7 years ago
You can purchase a variety of panel quantities on Ebay. They're really pretty reasonable too.
Search here and via google for "DIY solar panel". You'll have more plans than you can shake a stick at
Jack A Lopez
7 years ago
There are a couple of different levels to this.
What most people call a "solar panel", is a photovoltaic module, consisting of several smaller units called cells, all wired together.
The price for complete PV modules, at the time of this writing,  is about 5 to 10 USD per watt of available power in full sun.  Using this approximation, one would expect a new 40 watt PV module to cost about 5*40 to 10*40 = 200 to 400 USD.  So the modules are expensive.
As an alternative to this, some people sort of build their own modules from the cells.  There are a bunch of instructables on this subject, here:
https://www.instructables.com/pages/search/search.jsp?q=make+solar+panel
However, be warned that this can be kind of labor intensive.  I think a typical module based on silicon solar cells is going to be 36 of them wired in series.  It's a lot of connections, and the cells themselves can be tricky to solder to.  Also I am not sure about the quality of the finished module.  So I wonder if you actually gain anything, except knowledge, by building the modules yourself, compared to just buying them.
Anyway, I think the results of the search I linked to above will include details on where to buy the individual cells.  If not, the cells are sold by the usual surplus partsmongers, e.g.
http://www.goldmine-elec-products.com/products.asp?dept=1469
They're probably selling 'em on eBay too.
http://www.ebay.com/sch/i.html?_nkw=solar+cells&_sacat=See-All-Categories
steveastrouk
7 years ago
What do you mean by "making a solar panel" ? Do you mean soldering lots of cheap bits together, or do you mean making the "bits" themselves ?
