1192Views6Replies
amps vs milliamps ?
I have a ac/dc adapter with an output of 24V - 400mA. I am looking at a new adapter with an output of 24V - 1A. Will this damage the charger or battery? Thank u
11 years ago
In terms of power adapters, the amperage listed is the maximum current draw that the adaptor can supply. The device it's connected to will only draw as much as it needs. It's the voltage that you have to look out for, as circuits are often designed with one specific voltage in mind, and takes the current limiting from there. In short, it should be fine.
Answer 11 years ago
Thank u for ur help I appreciate it.
Answer 11 years ago
...although trying to get 150% more power out of the adapter you've got may cause it to overheat or otherwise fail.
If it's just for charging the same battery I'd go with dilandou on this.
L
Answer 11 years ago
I'm not trying to get more power just the same amount of power.
Answer 11 years ago
Then you're OK with what dilandou said.
L
Answer 11 years ago
For the author's sake, I concur :)
