552Views9Replies
Author Options:
any idea's on magnetic generators that would generate 34.5 watts output (3.5 volts, 7 amps) need to cut power costs. Answered
Aluminum Base1” long x ½” Diameter Oil Impregnated Brass Sleeve Bearing4” long x ½” Diameter Brass Shaft1 ¾” long x 2” Diameter Brass Rotor0.10” thick Mica Insulation0.005” thick Mylar Insulation0.04” thick Copper Coated Steel Wire (228 U-shaped pieces).032” thick Copper Coated Steel Wire (12 coils of 11 turns)0.014” thick Insulated Copper Wire12 Permanent Magnets ¾” long, 5/8” wide, 3/8” thick
o
Fe, Isotropic permanent magnet material cooled in a magnetic
field, Cast 9100 TS. 450 Brin, 2.2 Peak energy product. **
**magnet specifications: Alnico 4, M-60; 12 AL, 28 Ni, 5 Co, balCrimped Cooper clips0.30 thick Copper Tube 2” long x 2 ½” diameters.Acrylic Ring-Dimensions 3 ¾” O.D., 2 ¼” I.D., 3/8”0.002” thick Plastic Insulation PaperAcrylic holding shapesAcrylic domeLiquid Acrylic
  1. rough parts list Parts List (there is a list of parts suppliers in the next section):
frollard
frollard
Answer 11 years ago
that stuff IS bunk!
lemonie
lemonie
Answer 11 years ago
You can tell from the wording "magnetic generator", "cut power costs" - I just went to the trouble of finding something that matched.
L
frollard
frollard
Answer 11 years ago
really a magnetic generator really would work, if you had a free POWER source to generate electricity with....
lemonie
lemonie
Answer 11 years ago
Like wind..?
L
frollard
frollard
Answer 11 years ago
that site states it uses the earth's magnetic field to generate power :S
no wind involved!
orksecurity
orksecurity
Answer 11 years ago
No power generation involved either.
Kiteman
Kiteman
11 years ago
What are you running off 3.5V and 7A?
(You don't need to call it a "magnetic generator", as all electrical generators utilise magnetic fields.  It;s the nature of the beast.)
frollard
frollard
Answer 11 years ago
like a cheese quesadilla?
...hehe
I thought 3.5v7a was a bit much...
