13688Views8Replies
Author Options:
anyone knos how to remove a bike cassete without special tool? Answered
okay i got this mountain bike and i want to make the back rim single speed but i cant take out the cassete. i search on youtube but it says need a special tool but i cant find one in town. so if anyone knos how to remove a casset without the special tool HUM:)
FriendOfHumanity
FriendOfHumanity
9 years ago
Hello,
You may know this but there are two types of rear sprocket assembly:
- One is a freewheel and you may get away with the method that Caarnted suggests.
- The other type is called a cassette and,  again, you may get away with Caarnted's method but you will require a chainwhip which can be bought
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_525715_langId_-1_categoryId_242558
or simply made with an old chain screwed to a stick.
It stops the whole assembly moving as you try to undo the lockring.
I would suggest buying the tool online, it's only about £8 ; it is a joy to use andit will be essential when you need to change spokes on the drive side.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_714311_categoryId_242558_langId_-1?cm_sp=Intelligent_Offer-_-Product_Details_Zone_1-_-Blank&iozone=PDPz1
Good luck.
HmOnGbOi
HmOnGbOi
Answer 9 years ago
the spline is the special tool haha but ill try the homeade tool fashion one
FriendOfHumanity
FriendOfHumanity
Answer 9 years ago
HmOnGbOi ,
The spline shaped tool  is the special tool (cassette/freewheel remover) but I was pointing out that  if you are removing a cassette ( and not a freewheel)  you will also need a chain whip.
Kind Regards
FOH
The Skinnerz
The Skinnerz
9 years ago
Do you have any photos of the fixings that need to be removed to get the cassette off?
HmOnGbOi
HmOnGbOi
Answer 9 years ago
ill try to uplaod some photos of it
caarntedd
caarntedd
9 years ago
I've done it by placing the end of a punch or chisel in the notches around the inner edge of the "cassette" (I call it a cluster) and tapping it off with a hammer. Just put the wheel on something soft (like your lawn), rest your knees on the rim to stop it from moving, and bash away. Anti clockwise.
HmOnGbOi
HmOnGbOi
Answer 9 years ago
okay thnx! ill try that and let u kno what happens
