arduino coding problem
im working on a project of mine which needs an arduino to easily manipulate the PIR sensor and easily use its outputs via LED light.
this is my current program.
int ledPin = 13;
int pinPir = 2;
int val = 0;
int led2Pin = 12;
void setup() {
pinMode(ledPin, OUTPUT);
pinMode(pinPir, INPUT);
pinMode(led2Pin, OUTPUT);
Serial.begin(9600);
void calcLed(){
val = digitalRead(pinPir);
if (val == HIGH){
digitalWrite(ledPin, HIGH);
delay(5000);
else
digitalWrite(ledPin, LOW);
void loop(){
digitalWrite(led2Pin, HIGH);
calcLed();
delay(5000);
digitalWrite(led2Pin, LOW);
delay(2000);
im having a problem with how the sequence of the program works.
when i test the project . its works fine. but while the program is running . it seems that it wont
recognize the input of the Pir sensor until the program is done?
how can i intervene ? i want the program to go back to 1st step when the PIR sensor . detects motion.
please help? thankyou :)
6 years ago
Did you look into the code samples for the PIR sensor? Tutorials on arduino.cc
I don't know where the gndPin comes into play in your program. The PIR sensor has to be initialized to "warm up" and then monitored for any changes in reading. Good luck.
Reply 6 years ago
i didnt know that the pir needed to "warm up" thankyou . i'll start looking into it.
and the gndpin. is actually the led2pin. i forgot to edit that one. and now i have. thankyou again.
