2356Views3Replies
Author Options:
are these pins for parallel port on my pc's motherboard?? Answered
Take a look at this image there is written PARALLEL and my computer lack prallel ports at the back where it should be with others
Vyger
Vyger
Best Answer 7 years ago
They no longer put the connectors for serial or parallel ports on the rear connector panel. Those boards that do have the ports use connectors on the board, as your picture shows. You need a ribbon connector that goes from the board plug in to either a cut out in the case or a metal slot filler that has the port plug in it. That is, if you want to use the port.
