108Views10Replies
Author Options:
bearing to shaft Answered
How would I secure a 1/4" id bearing to a 1/4"shaft? The bearing slides on very easily and is a little sloppy.
I bought these from a supply co. thinking a 1/4" id bearing would fit properly on a 1/4"shaft.
Any one have and ideas?
RavensCraft
RavensCraft
7 years ago
Step1.Take some vise grips (preferably vice grips with unworn grooves in the jaws) and grip the rod
           where you want the bearing to be.
Step2.Hit the vice grips so that they slide along the shaft , thus slightly gouging the shaft and
          providing a press fit for the bearing.
ecafighter
ecafighter
Reply 7 years ago
Good answer RavensCraft!!
I will do that.
ecafighter
ecafighter
ecafighter
7 years ago
Thanks to all. I appreciate the answers
TLM-1507 :: 1/4" X 12" STEEL LINEAR $6.69 13.38 EA In 2 / 0
2 DMB-98 :: .25 X .75 X .2812 524 LB MAX
Above items are the ones in question, from Reid Supply.
I think the epoxy is the way to go.
Thanks again for the comments.
verence
verence
7 years ago
"a 1/4" id bearing to a 1/4"shaft"
Can you somehow translate that for the imperially challenged (i.e. metrically handicapped)?
verence
verence
Reply 7 years ago
Yep, that's for the '1/4"' part, "Wolfram Alpha" can figure that out :-)
But what about  the 'xx id bearing to a xx shaft' part?
Sorry. but English (especially the technical part) is still a second language to me.
Raised truly metrically, I'd have thought that any "y..." hole would fit (with a little persuading force) on a "y..." shaft. ... or the other way 'round.
steveastrouk
steveastrouk
Reply 7 years ago
...with a little persuading force....
That made me wince.
You need to look at "tolerancing", the science of making bits fit together...
I don't know what's gone wrong here. Generally SHAFTING is reasonably precise, +/- 50um = +/- 0.002" = +/1 "one thou". GOOD quality shaft is +/-2.5um, +/- 0.0001"
Holes are different matter, and fits depend on the manufacturer. A drilled hole, done badly is as much as 250um bigger (0.01") than its nominal size, a REAMED hole, done well, will be within that 2.5um range. Now you have to arrange a tolerance band to maintain say a worst case gap of 10um, so the hole is specced as 6.35mm+.005 - 0.000, and the shaft specced at +0, -0,005. Now, however the parts are made, to be in spec, they will fit.
steveastrouk
steveastrouk
7 years ago
The classic method is to cross drill the bush and tap a thread for a screw.
ecafighter
ecafighter
7 years ago
I had thought about the epoxy but wanted to see what others had done.
Thanks for the reply. Plenty of choices.
Kiteman
Kiteman
7 years ago
It depends how permanent, how strong, and how tidy you want the fix.
A drop of superglue?
A blob of epoxy?
A mess of hot glue?
A matrix of Sugru?
A thin metal shim?
A collar of heat-shrink?
A small bolt drilled through to the shaft?
