45865Views17Replies
Author Options:
best solid material that dissolves in water? Answered
I need a solid material I can easy get, it should stay solid when exposed to air, for long periods, and when it comes into water, it should dissolve. What material would be the best choice? edit: It should stay firm for about 5 years. When in water, it needs to dissolve as quick as possible.
MahavishnuMan
Best Answer 10 years ago
Hmm, this is a puzzler. On one hand, if solubility is more important (as you want the float to be released as quickly as possible) you could try something like either sugar or citric acid and baking soda (the active ingredients in Alka-Seltzer and bath bombs). However, you would sacrifice shelf life as I don't think it could be stored for 5 years (however, it's still cheap enough to manufacture repeatedly). On the other hand, if you're going for storage you could try the aforementioned salt, or perhaps gelatin, as they use in pills. It might take awhile to dissolve though. I'm still trying to figure out a happy medium (no pun intended). I'll check back soon if I think of anything.
merijnvwMahavishnuMan
Answer 10 years ago
That bath bombs idea is not bad, I'll think of it. thanks! I'm now testing with paper towel pills that are made from small wet paper towel pieces and dried. It doesn't dissolve in air because it doesn't dissolve in water, but in water it does tear apart(I think, I hope it will tear aopart enough, that's why I'm testing it)
MahavishnuManmerijnvw
Answer 10 years ago
Perhaps you could make pulp from wet toilet paper, then pack it around the float. Once it dries, it should stay hard, but in water I would imagine it would break apart really easily. Maybe mashing in some bath bomb would help expedite the process?
Johnh326
7 months ago
Am looking for a hard material for use in an outdoor sculpture that can dissolve over time without causing any environmental damage. Idea is that it would be hard enough to maintain its shape and withstand assaults by climbing kids, etc,. for about a year before gradually dissolving without much of a trace. Have thought about some kind of salt mixture, perhaps gesso, or glue and paper. Your ideas?
PixelBuster
8 months ago
How about glue, like Elmer's school glue. It's moldable, very hard, keeps well even in standard humidity, and it dissolves in water rather quickly. Wouldn't recommend bath bombs or the like as its expensive and it definitely won't keep for 5 years if exposed to the air.
LarkspurBrad
9 years ago
Great question, I've got a different use in mind but was researching the subject when I ran into this discussion. What I discovered was the pill gelatin requires the water to be a body temperature to work. In something like lake water it will just deform. Keep us posted on the paper test.
Gorfram
10 years ago
Smugglers in waters off the Northeastern US used to use bags of salt:
  • Upon appproach of law/customs enforcement vessel, tie contraband to large bag of salt pre-rigged to small float and drop overboard.
  • "Why, gosh, Mr. Officer, sir, we're just out for a little night fishing. Contraband? Who, us?"
  • Come back later after salt has disolved and pick up float, contraband, and now-empty salt bag.
For a solid block of salt, anywhere that sells feed for livestock will also sell solid "salt licks."
OTOH, sugar is easier to manipulate (as spun sugar, rock candy, etc.) into a form that may better suit your purpose.
Or maybe solid/bar soap?
And - sorry, I can't resist - ice is nicely solid when exposed to air below 32 F, but melts quickly in water above 32 F :).
merijnvwGorfram
Answer 10 years ago
Thanks for your answer, I'm using it somewhat in the same way as the smugglers you described, I'm going to use it in a safety float for my camera. When it falls into the water I need to get it out quick enough to still be able to repair it by putting it in the oven for a while. That won't work in a lot of nature waters without a float, so I'm building that float. That's why the stuff needs to dissolve quick. About hwo quick would a half-centimeter layer of a 'salt lick' dissolve in water?
Grathiomerijnvw
Answer 10 years ago
I'm not sure a salt lick is going to be the best source. They are very dense, unlike sugar cubes and there are no pores for liquid to get inside of it. They can survive being outside in the rain with only minimal melting. How about using paper as your fuse? I'm unclear about the actual deployment of your float, but there are a few ways you can use it to trigger something. One way would be to have a piece of metal held in place with paper. When the paper gets wet the metal will fall freely through the paper. Another way would be to tension a spring by hooking one end on a piece of paper. When it got wet the paper would tear and release the tension.
merijnvwGrathio
Answer 10 years ago
Paper! thanks for saying that because then I thought of toilet paper. You can make pills or balls from it if you make it wet and let it dry. That doesn't dissolve when it's exposed to air and it can handle some water drips, but whjen completely under water it breaks down. I'm testing it now with paper towel, I first cut it into small pieces and made a wet pill from it. Now it's drying. I think your idea with the spring would give too much stresson the paper, so after a long time also in the air it will tear. Thanks
Re-designmerijnvw
Answer 10 years ago
Are you trying to build a float that stay stowed in a tiny package until it gets wet then deploys on contact with water. If it were me designing a system like that I would look toward using an electrical system with exposed contacts that would open a valve and allow a co2 ctg. to fill a bladder.
merijnvwRe-design
Answer 10 years ago
Yes you got me right. good thinking but I think my way would be almost as effective and way less complicated so I'll stick to that. thanks
Padlock
10 years ago
Maybe if you bought one of these you could fashion something out of it.
VLOEIBEER
10 years ago
A certain type of bears dissolve in water which I happen to be a member of.
Bigev
10 years ago
Sugar Cubes
merijnvwBigev
Answer 10 years ago
That's actually not a bad idea, I'm stupid I haven't thought of that! I only thought about solid salt but I think that doesn't dissolve quick enough. I'm still open to better options
MahavishnuMan
10 years ago
Hmm. How long is a long period? After all, humidity in the air will, over time, start to dissolve whatever is soluble in water.
Re-design
10 years ago
That was going to be my answer also. Tell us more about what you are planning and we may be able to come up with a better answer.
