I read that bi-diesel works in any diesel engine. LasVegas mentioned using vegetable oil, which is ok, but it will clog up your engine very fast. Good Luck.
You need to remeber vegetable based diesel will also attack all rubber lines, seals, and gaskets .... So they will swell, leak or rupture and usally they wait till your 200 miles from home and it's -20 out and your just outta cell coverage ....
So Change them with sythetic lines and seals, and read your owners manual it should tell you if your veichal can run BioDiesel.... But other then that it has a higher Cetane rating and better lube quilities so it'll run in your diesel and your engine will run longer before requiring a overhaul / rebuild
its not the vegitable oil that eats the seals it is the ethanol you make it with. you can distill it out and no mods are require also biodeisal is not just vegetable oil . and yes a deisal engine will run on vege oil if its not direct injection.
All it takes to run a diesel engine off of vegetable oil is to filter the oil if it's used and then put it through an aerator prior to going to the engine. The very first diesel engine ran off of vegetable oil.
Converting a gasoline combustion engine would take quite a bit more since it's not designed to run at such low temperatures.
how do you deal with all the other nice junk in the oil like glycerne and acids ??
It's easy enough to process and titration will make waste oil better then oil based diesel, but I don't think aeration would work for long on most small diesels, Or are you powering a huge engine which normally runs on bunker oil or unrefined crude (( typically on large ships like oiltankers ))
And on the Coversion from gas to diesel most even done by manufactures really suck when compared to built for diesel engine ...
Well we run our 1.9D turbo puegot 406 on bio-diesel, rapeseed oil to be honest, in winter the engine will get rough and splutter at random as the oil thicken at low temperatures, however a 10% mix of normal diesel added will keep it alive, with the forklift we never had trouble running the same fuel, then again thanks to the silt in the tank someone had cut the hose short as a lazy solution so the still thin oil got taken in by an old mechanical fuel pump with some ferocity, not speed just a rather violent pump (secretly a hydraulics pump that was a close match)
Your diesel(?) engine does't need to be converted, you can just run it on different fuel. If you don't have a diesel forget it, otherwise just make sure your fuel is clean.
L
13 years ago
Reply 13 years ago
You need to remeber vegetable based diesel will also attack all rubber lines, seals, and gaskets .... So they will swell, leak or rupture and usally they wait till your 200 miles from home and it's -20 out and your just outta cell coverage .... So Change them with sythetic lines and seals, and read your owners manual it should tell you if your veichal can run BioDiesel.... But other then that it has a higher Cetane rating and better lube quilities so it'll run in your diesel and your engine will run longer before requiring a overhaul / rebuild
Reply 11 years ago
13 years ago
I have a whole series of instructables on biodiesel coming up, so watch for them! I'm not sure how to convert an engine though...
Reply 12 years ago
Saw 'em! Here's one, for those who haven't seen them:
https://www.instructables.com/id/Make-Biodiesel/
13 years ago
All it takes to run a diesel engine off of vegetable oil is to filter the oil if it's used and then put it through an aerator prior to going to the engine. The very first diesel engine ran off of vegetable oil. Converting a gasoline combustion engine would take quite a bit more since it's not designed to run at such low temperatures.
Reply 13 years ago
how do you deal with all the other nice junk in the oil like glycerne and acids ?? It's easy enough to process and titration will make waste oil better then oil based diesel, but I don't think aeration would work for long on most small diesels, Or are you powering a huge engine which normally runs on bunker oil or unrefined crude (( typically on large ships like oiltankers )) And on the Coversion from gas to diesel most even done by manufactures really suck when compared to built for diesel engine ...
Reply 13 years ago
Reply 13 years ago
. What is the aerator for? Enhanced atomization at the injectors?
13 years ago
How much do you know about the differences between diesel and gas motors, and what type of gas engine are you considering trying to convert?
13 years ago
Your diesel(?) engine does't need to be converted, you can just run it on different fuel. If you don't have a diesel forget it, otherwise just make sure your fuel is clean. L
