218Views8Replies
Author Options:
black,red,green and white power cable supplying cree 3led bike light is broken. Answered
 I need help identifying which colour goes to which point.There are four points marked A G V B  on the PCB and i need to solder the 4 colours  onto their respective correct points.The cloured cables are coming from the battery and will be soldered on the cree LED pcb.
iceng
iceng
Best Answer 7 years ago
Red, Green, Blue
What is the Cree LED part number
A battery usually has only two wires.
We need more details ?
What is actually broken ?
teemandi
teemandi
7 years ago
Thanks for your replies everybody.I can't see any part number.but I should say this is forhhigh power bike light and has dim switches ,maybe the other wires ha ve something to do with that.
iceng
iceng
Answer 7 years ago
  • You can take pictures with any phone
  • eMail them to yourself
  • SAVE them to a file (call it ibles or whatever you like)
  • Rotate them right for proper viewing
  • Log on here
  • Under your page picture click Image Library
  • Then select  Choose Files
  • Find your ibles file and select a picture
  • Press open and then Upload Files
  • Now the picture is in your library and can be added to your question.
Josehf Murchison
Josehf Murchison
7 years ago
Make and model would be a help.
AGVB is red green white black.
Joe
iceng
iceng
Answer 7 years ago
I don't doubt you but would dearly like to know the derivation A=Red.
Then given four wires, one has to be common Anode or common Kathode wire.
Josehf Murchison
Josehf Murchison
Answer 7 years ago
I said make and model would help.
It is not a standard yellow (Left) green (Right) brown (Running) white (Ground)
A red left, G green right, V white ground, and B black running
I have done a few tail lights
iceng
iceng
Answer 7 years ago
AHhaa ..... I get it
Lots of newbies forget to czech up on their question
After all this is a discourse.
Josehf Murchison
Josehf Murchison
Answer 7 years ago
I could have said that better also.
Standard North American vehicle lights wiring color code is yellow (Left) green (Right) brown (Running) white (Ground)
But we live in a global economy so you are bound to run into something different.
