177Views1Replies
Author Options:
building a picture frame? Answered
Have an older Toshiba 2595 lap top (don't even remember how I acquired it, blame that one on the “Old Timers Disease” that I have). I am going to build a Digital Picture Frame from it.
When I acquired it there was no battery or power supply with it. While doing some repair work on a similar computer for a friend, I did power it up with his battery and installed Windows 98 SE on the hard drive, so I know the unit works. The HD is only a 6 Gig, but is big enough to hold a couple of hundred pictures and the software program “Slideshow” to rotate them.
What I need to know is, will this work on the power supply only. Do I need to do anything with the battery connections? There are 10 pins where the battery went into the computer and I don’t have any idea of which ones did what.
Does anyone know what rating of power supply is required for this unit. Could I use a generic power supply instead of having to purchase the exact one for this unit?
Of course you know there will be another upcoming “instructable” of how to build a Digital Picture Frame. I will try and make mine a bit more entertaining and perhaps include some new idea about how to do this type of thing.
Thanks
Larystoy
jeff-o
jeff-o
10 years ago
Do you know the voltage and current output of the power supply you need?  With that info, all you have to do is match them up and you should be good to go.  It should run just fine with no battery installed.
