15Views1Replies
Author Options:
button_input_led_output:115: error: variable or field 'handleMessage' ? Answered
Hi and thanks for your efforts with this course and in answering questions. I am using a generic esp8266 module and have managed to solve problems so far with my own research but this one has me stumped. I am getting the following error messages when compiling the button_input_led_output sketch:
button_input_led_output:115: error: variable or field 'handleMessage' declared void
void handleMessage(AdafruitIO_Data *data) {
button_input_led_output:115: error: 'AdafruitIO_Data' was not declared in this scope
button_input_led_output:115: error: 'data' was not declared in this scope
button_input_led_output:45: error: redefinition of 'int current'
int current = 0;
IOT_Class_LED_Button:5: error: 'int current' previously defined here
int current = 0;
button_input_led_output:46: error: redefinition of 'int last'
int last = 0;
IOT_Class_LED_Button:6: error: 'int last' previously defined here
int last = 0;
C:\Users\Heinz\Documents\Arduino\IOT_Class_LED_Button\button_input_led_output.ino: In function 'void setup()':
button_input_led_output:51: error: redefinition of 'void setup()'
void setup() {
IOT_Class_LED_Button:8: error: 'void setup()' previously defined here
void setup() {
button_input_led_output:68: error: 'handleMessage' was not declared in this scope
command->onMessage(handleMessage);
C:\Users\Heinz\Documents\Arduino\IOT_Class_LED_Button\button_input_led_output.ino: In function 'void loop()':
button_input_led_output:82: error: redefinition of 'void loop()'
void loop() {
IOT_Class_LED_Button:13: error: 'void loop()' previously defined here
void loop() {
exit status 1
I am guessing that the problem lies with the AdafruitIO.h library which as discussed in the question 'AdafruitIO.h not loading' question is not highlighted in orange on my sketch. I have tried removing and reloading this library as well as loading previous versions, with no luck.
Your thoughts on this are greatly appreciated.
Regards Heinz
bekathwia
Best Answer 23 days ago
It looks like you pasted the code more than once in your editor ("previously defined here" and "redefinition" errors). You should also check you have all the required libraries installed as described in the lesson, including the Adafruit IO Arduino library.
