319Views24Replies
Author Options:
can anyone provide me with some schematics for a function generator with only a 147.7 square wave AC signal? Answered
can anyone provide me with some schematics for a function generator with only a 147.7 square wave AC signal? and im trying to make a it as small as possible
steveastrouk
steveastrouk
Best Answer 7 years ago
If this is for "wireless power", just use a 555 timer.
tykora
tykora
Answer 7 years ago
so if you could get me a schematic of how I could use it
tykora
tykora
Answer 7 years ago
an actual circuit schematic would be more helpful
steveastrouk
steveastrouk
Answer 7 years ago
That WAS an "actual circuit". Plug in the values I worked out, and possibly put a transistor there to drive your coil.
tykora
tykora
Answer 7 years ago
oh :P (this is why I ask for help)
thx I couldn't recognize it
tykora
tykora
Answer 7 years ago
everyone keeps telling me that but I haven't learned enough yet to but a schematic together yet
tykora
tykora
Answer 7 years ago
put*
Josehf Murchison
Josehf Murchison
7 years ago
See helps to be concise.
Try this built right the circuit is about the size of a match box.
tykora
tykora
Answer 7 years ago
there are no 147.7kHz crystals or 0.1477MHz
Josehf Murchison
Josehf Murchison
Answer 7 years ago
If you cant find a 147.7 try these.
I know you can find 147.5 on the net add a .2 and mix giving you a 147.7
Go higher and PMW down.
Go higher and counter down.
tykora
tykora
Answer 7 years ago
ive been all over the web still cant find any that add up to the frequency im looking for
tykora
tykora
Answer 7 years ago
yah.. cant find them on there either
Josehf Murchison
Josehf Murchison
Answer 7 years ago
The crystal in the datasheet goes from 30 to 180 kHz
Just order one in 147.7 kHz
tykora
tykora
Answer 7 years ago
it wont let me create an account to order one
tykora
tykora
Answer 7 years ago
and there all out of stock
Josehf Murchison
Josehf Murchison
Answer 7 years ago
Well if you can’t get a crystal get a SN74LS629 voltage controlled oscillator and adjust it to 1477000 Hz then run the 1477000 Hz through a decade counter like a 4017 to give you a 147700 Hz frequency.
Josehf Murchison
Josehf Murchison
7 years ago
Now here is a silly question 147.7 what?
Hz, kHz or MHz.
The thought just struck me be concise or you may not get the answer you want.
tykora
tykora
Answer 7 years ago
sry kHz
steveastrouk
steveastrouk
7 years ago
How accurate does the output have to be ? Can you make that frequency from dividing a standard crystal frequency by an integer ?
Josehf Murchison
Josehf Murchison
Answer 7 years ago
Steve 147.7 what?
He didn't say.
steveastrouk
steveastrouk
Answer 7 years ago
He he, you're right !
Josehf Murchison
Josehf Murchison
Answer 7 years ago
It struck me that is a standard crystal.
Josehf Murchison
Josehf Murchison
7 years ago
That is a very tight frequency.
You can make it with a 555 timer.
But no matter what way you make it you will need a oscilloscope for fine tuning.
steveastrouk
steveastrouk
Answer 7 years ago
...unless its crystal locked.
