15882Views8Replies
Author Options:
can anyone suggest an alternative for TIP31? Answered
Hi!I want to use a TIP31 in my infra red detector circuit and cant find it any shop,could anyone suggest any other transisitor which fulfills the same purpose?
Tags:tip31
steveastrouk
steveastrouk
Best Answer 8 years ago
What's it switching ? A TIP32 is a power darlington. Find an equivalent one that can handle the switching current and volts.
Steve
cuyler1
cuyler1
Answer 4 years ago
they are obsolete now 2016 and no availability. What now? I keep getting the same answers from the electronics forums because they "know it all !"
mpilchfamily
mpilchfamily
Answer 4 years ago
A simple google search for tip31 and looking at shopping will give you several places that still carry them. Ebay is one source. China still sells it all. There are also sights that will help you find suitable replacements. Google tip31 replacements for that. Just be sure to go over the data sheets. Compare the specs and make sure any recommended replacement has similar specs and the specs are within the needs of your circuit. See the exert from the data sheet attached.
rakeshanand
rakeshanand
4 years ago
TIP31C is Equivalent to:
2N6122, TIP31B, MJE340K, SW4F013
samtechpro
samtechpro
7 years ago
2SD313 is available in market everywhere. And it is eqvivalent to yours.
WWC
WWC
8 years ago
These are all the equivalent crosses for a TIP31
http://alltransistors.com/crsearch.php?mat=Si&struct=npn&pc=40W&ucb=80V&uce=40V&ueb=5V&ic=3A&tj=150%C2%B0C&ft=3MHz&cc=&hfe=20/100&mnf=&caps=TO220
quatch
quatch
8 years ago
or here: http://www.digikey.ca/product-search/en/discrete-semiconductor-products/transistors-bjt-single/1376376?k=TIP31
Otherwise (I am no expert here) look for something with the same gain (hfe) and current/voltage ratings.
