There exist ATX power supplies intended to be powered from a 12 volt battery, intended to be used for with car computers.
I think using an inverter, together with a ordinary mains powered ATX power supply, will waste power, and produce a lot of 60 Hz, and 120 Hz noise, you do not want.
With the right inverter you can wire 3 or 4 PC to a car. Though it will be a heavy strain on the car's electrical system. If the alternator isn't able to keep up you can kill the battery pretty fast.
8 years ago
yeah, you have to use an inverter, check this out:
http://www.ebay.com/sch/Power-Inverters-/58020/i.html
good luck
Answer 8 years ago
looks like im gonna need a inverter. thats fine, just wanted to know if it were a way to reuse parts that i had laying around thanks evreyone
8 years ago
Switch out the inverter, and use a DC-DC power supply
http://www.mini-box.com/DC-DC
8 years ago
You could probably use the 12V supply from the car, in some way (without the ATX PSU).
L
8 years ago
The links below, I found via a Google(r) search using the words:
car + computer + 12v +atx
(http://www.google.com/search?hl=en&q=car+computer+12v+atx)
http://store.mp3car.com/M2_ATX_160W_Intelligent_DC_DC_PSU_p/pwr-015.htm
http://www.mini-box.com/M2-ATX-160w-Intelligent-Automotive-DC-DC-Power-Supply?sc=8&category=101
http://www.powerstream.com/DC-PC-12V.htm
8 years ago
