623Views9Replies
Author Options:
can concrete be rotomoulded as you would plastic powder? Answered
aeray
8 years ago
Maybe, but probably not. A concrete delivery truck is basically a giant mobile rotomold, right? It keeps it from curing.
Re-designaeray
Answer 8 years ago
Movement in the mixer truck does not keep it from curing. Once the water is added the driver has about 45 mins to 1 hour to unload or it sets up in the truck rotating or not.
When conc. companies bid jobs more than 30 min. away they either trade with a competitor close to the job site or set up a small batch plant close to the job.
caarnteddRe-design
Answer 8 years ago
Retardants can be added to extend the workable period. Concrete is pretty high tech these days, with many additives available. Water reducers, retardants, accelerants, waterproofing, plasticisers. Inevitably it all goes off eventually.
stephen maherRe-design
Answer 8 years ago
Quite correct but Ihave found a site where its been done.'michaelsblog'Thanks for answer
aerayRe-design
Answer 8 years ago
I agree. In my area, they sometimes make the run dry and add water at the jobsite. It's hard to hit the slump just right though.
I shouldn't have said "keeps it from curing". But it does delay it.
An anecdote: I have a buddy who spent a whole summer chipping cured concrete out of mix trucks, in the sun, wearing a respirator and full coveralls. He lost about 20 lbs.
Shotcrete is a good idea too.
stephen maheraeray
Answer 8 years ago
I actually found 'michaelsblog' and these guys have done it 7-12-2010.I googled 'concrete rotational moulding'Very interesting.thanks for your quick response .
aeraystephen maher
Answer 8 years ago
I can't seem to find the site you're looking at, but I'm quite interested. Are they using it for ferro-cement boat building? What are you wanting to use it for?
lemonie
8 years ago
If you are talking about casting concrete-shells in rotary-moulds yes sure. But why?
L
Re-design
8 years ago
Yes. make a dryish mix with pea gravel and have at it.
If can also be shot from an air gun.  Google "gunite".  It's how they spray swimming pool walls.
